thinking about blox type B's
Old May 6, 2007 | 05:58 PM
thegatekeeper14's Avatar
Default thinking about blox type B's
i have a 2000 JDM ITR swap in my teg. i was thinking bout getting the blox type B's. i plan on using my stock valvetrain and throwing in a rev limiter to save my engine.
my Question is has anyone have any experince using the Blox B stage 2 in the gsr or type r?
and what the resaults were and if daily driving is ok
Old May 6, 2007 | 09:08 PM
Circuit Star-29's Avatar
Default Re: thinking about blox type B's (thegatekeeper14)
With tuning you will love them. You shouldn't use stock valve springs, though... At least portflow inner springs.
Old May 6, 2007 | 09:12 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegatekeeper14 &raquo;</TD></TR><TR><TD CLASS="quote"> plan on using my stock valvetrain and throwing in a rev limiter to save my engine.
No, not safe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegatekeeper14 &raquo;</TD></TR><TR><TD CLASS="quote">my Question is has anyone have any experince using the Blox B stage 2 in the gsr or type r?
They are copies of Skunk2 cams, forgot which specific model though.
Old Jul 13, 2007 | 01:32 PM
BLOX_gsr's Avatar
Default Re: thinking about blox type B's (neo_)
im using them. heres my setup
jdm itr header w/ itr cat
p28
skunk2 pro series manifold
skunk2 cam gears
Rocket valve spring and retainer
blox type b cams
i love it!
Old Jul 13, 2007 | 02:18 PM
robfrmny21's Avatar
i understand they are copies of sk2 but has any one seen any unusal wear from these cams? or any others?
i know some cams wear timing belts out whats have you guys seen?
Old Jul 14, 2007 | 11:55 AM
donz's Avatar
Default Re: (robfrmny21)
there is a beefier timing belt that you should consider, which i thought was a good idea. it's made by power enterprises or something like that. Some one else chime in!
Old Jul 14, 2007 | 12:36 PM
Default Re: (donz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robfrmny21 &raquo;</TD></TR><TR><TD CLASS="quote">i understand they are copies of sk2 but has any one seen any unusal wear from these cams? or any others?
i know some cams wear timing belts out whats have you guys seen?</TD></TR></TABLE>
Valve spring pressure, combined with high compression will cause premature T-belt failure... The trick is finding the correct valve spring to compliment the cams.
Old Jul 14, 2007 | 02:52 PM
vinuneuro's Avatar
Default Re: (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">
Valve spring pressure, combined with high compression will cause premature T-belt failure... The trick is finding the correct valve spring to compliment the cams.</TD></TR></TABLE>
Can you explain this please?
Old Jul 14, 2007 | 03:36 PM
Default Re: (vig)
High compression = tension placed on belt when the ramp of the lobe on the cam begins to roll into the rocker. This is dependent on cam timing.
Valve pressure = How much tension the belt is absorbing while trying to rotate the cam through its timing cycle.
Usually, the two are combined because rarely does a motor run High compression without the necessary cams to take advantage of the compression... And its just ridiculous to run a huge cam without compression. Further more, you SHOULD NOT run valve springs that do not provide the enough pressure to avoid valve float. Its a fine line, imo.
Old Jul 14, 2007 | 08:01 PM
AllMotorDan's Avatar
I'm about to finish my poorman's type r build and i've got the type b cams and blox valvetrain so im pretty excited to see how it turns out.
Old Jul 18, 2007 | 12:52 PM
BLOX_gsr's Avatar
Default Re: (AllMotorDan)
u'll love it.
Old Oct 14, 2009 | 11:43 PM
Conflicted's Avatar
So who makes the sturdier and beefier belts?
Old Oct 15, 2009 | 07:42 AM
Tyrant_007's Avatar
I think Toda makes a nice belt. GUILOTINE has a nice one on his build too. Can't remember whiich belt it was though. Just look at his thread.
tomman2001
Oct 18, 2007 06:24 PM
crxgator
Apr 6, 2007 06:29 PM
H22A EG6
Nov 3, 2004 09:11 AM
H22A_HB
Aug 27, 2004 11:13 PM
Dream
Aug 15, 2003 09:08 AM
