Knock Sensor / Evap / LS Crank Pulley / P30 FlyWheel / Thermostat / VSS / 98 gsr obd2a wire harness
Vtec Solenoid $SOLD
A/C Pulley w/Bracket $22
98 GSR obd2a Engine Harness Uncut. $SOLD - Needs new Clip for CKF Sensor that can be purchased at any honda parts dealer. (see pic)
Pic of clip that needs to be replace
P72 Lower Tranny to Block Bracket $15 - (I have no idea what this part is called. See pic.)
Knock Sensor $SOLD - Works for d and b series maybe h series too if i remember correctly.
LS Crank Pulley w/key pin $17 - If you don't use A/C then this will do just fine.
Thermostat $7
VSS Vehicle Speed Sensor $SOLD
P30 Del Sol FlyWheel $SOLD[img]
http://i171.photobucket.com/albums/u...6.jpg[/img]
Evap Sensor - $SOLD
PM me!
Modified by SiViK-R at 7:30 PM 5/7/2007
Modified by SiViK-R at 11:03 PM 5/7/2007
Modified by SiViK-R at 5:03 PM 5/9/2007
Modified by SiViK-R at 3:24 PM 5/11/2007
Modified by SiViK-R at 5:52 PM 5/30/2007
Modified by SiViK-R at 4:35 PM 6/2/2007
Modified by SiViK-R at 3:13 PM 6/8/2007
Thermostat $7
Evap Sensor - $SOLD
PM me!
the vss sensor works on pretty much any manual right....i need it for a 98 accord manual....with it work??
