d16a1 pistons in d16a6 block will it work?
Old May 6, 2007 | 03:23 PM
projectef's Avatar
Default d16a1 pistons in d16a6 block will it work?
i heard that u can put the 1st gen d16a1 pistons in the a6 block to make the comp... higher is that true?
Old May 6, 2007 | 03:57 PM
SIXTY's Avatar
Default Re: d16a1 pistons in d16a6 block will it work? (projectef)
yes
Old May 6, 2007 | 04:53 PM
projectef's Avatar
is there any fab... that you have to do to make it fit?
Old May 6, 2007 | 05:16 PM
Tippyman's Avatar
Default Re: (projectef)
Someone correct me if I'm wrong, but they bolt right in, correct?
The stock wrist pins are press in, though, so you might need to get a machine shop to assemble them for you.
Old May 6, 2007 | 05:27 PM
projectef's Avatar
is it going to hit with the z6 head
Old May 6, 2007 | 06:27 PM
JUN.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef &raquo;</TD></TR><TR><TD CLASS="quote">is it going to hit with the z6 head</TD></TR></TABLE>
nop, but You have to be carefull with the lift of aftermarket cams for the z6 head
Old May 6, 2007 | 09:28 PM
crooked muffler's Avatar
Default Re: (JUN.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN. &raquo;</TD></TR><TR><TD CLASS="quote">
nop, but You have to be carefull with the lift of aftermarket cams for the z6 head</TD></TR></TABLE>
word up
Old May 6, 2007 | 09:44 PM
projectef's Avatar
what be comp... like? will it b 2 high for street?
Old May 6, 2007 | 10:32 PM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef &raquo;</TD></TR><TR><TD CLASS="quote">is there any fab... that you have to do to make it fit?</TD></TR></TABLE> none at all...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef &raquo;</TD></TR><TR><TD CLASS="quote">what be comp... like? will it b 2 high for street?</TD></TR></TABLE> its not that dramatic, you can drive it on street, but get it legally smogged may be a little harder
Old May 7, 2007 | 04:03 PM
projectef's Avatar
y is that? is it b-cuz the comp.. is 2 high?
Old May 7, 2007 | 04:11 PM
Janos Lin's Avatar
Not too high, just higher than stock which makes it burn better, but it will also burn hotter raising NOx emissions but dropping HC emissions. I don't think it will make a big difference. 11.3:1 compared to 9.1:1 but you do pretty much need to run 91 octane gas.
Janos
Old May 7, 2007 | 08:35 PM
projectef's Avatar
yup 91 octane is wat i use. aite thanks for the help.
EnyKnight
Jan 15, 2025 09:14 PM
ZCcivicBOI
15
Nov 26, 2007 07:01 AM
projectef
36
May 15, 2007 10:09 PM
donaldmejr
Jul 13, 2006 11:08 AM
