heads shot
Old May 6, 2007 | 03:03 PM
krazeenoy's Avatar
Default car problems
a mechanic told me that the head is shot in the motor and the timing doesnt catch ...because im trying to buy the car...and could i fix the timing and it would start?
Modified by krazeenoy at 4:32 PM 5/6/2007
Old May 6, 2007 | 03:20 PM
Jtuned DC2's Avatar
* B A N N E D *
The head is shot? and the timing doesnt catch? Timing is fixable but what does he mean by shot? The valves are bent?
Old May 6, 2007 | 03:34 PM
deadline's Avatar
NEW motor time
Old May 6, 2007 | 03:53 PM
krazeenoy's Avatar
does it mean i need a new motor if the head is shot...or could i get another head for it?
Old May 6, 2007 | 03:55 PM
sickofitall1113's Avatar
just new head. but why did he say it was "shot"
Old May 6, 2007 | 04:06 PM
krazeenoy's Avatar
Default Re: (sickofitall1113)
i dont know...he only said it was shot...does any one know what dat means
Old May 6, 2007 | 04:11 PM
lsvtek's Avatar
Default Re: (krazeenoy)
maybe the head is done for?
Old May 6, 2007 | 04:55 PM
doood's Avatar
been there done that
take the car to a mechanic that will give you a reason as to why the head is "shot" and not one that just says so.
Old May 6, 2007 | 11:13 PM
krazeenoy's Avatar
yeah i would take it to the mechanic but if its only the head...my friend could change it for me..its cheap with a clean body...going to take a look at it tomrrow....if he says the heads are shot...does that mean that the block is no good too?
Old May 7, 2007 | 03:47 AM
krazeenoy's Avatar
anyone know if the block is still good
Old May 7, 2007 | 04:25 AM
onesikdb8's Avatar
It all depends on whether the pistons smacked the valve or not. You won't know until you pull the head off.
Old May 7, 2007 | 04:49 AM
g0tgot's Avatar
most likeley the pistons are still good, it is kind of rare when the pistons hit the valves from the timing being off, but it does happen frequently ......... i would ask him if all checks out except for the head how much he would sell for, a good machine shop can remove and replace the valves for about an average of $220 (with the head allready removed)....FYI
Old May 7, 2007 | 06:48 AM
mike-y's Avatar
Default Re: car problems (krazeenoy)
Timing belt probably broke and you could have bent some valves. IF you are lucky, you didn't bend the valves, and you can put in a new timing belt and the car will run. but that's very rare. Most likely, you will need to pull the head and replace the bent valves.
Old May 7, 2007 | 12:56 PM
krazeenoy's Avatar
i was just thinking of replacing the head with another ls head i have and try to do the timing..if that doesnt work then i guess i can re sell the shell...
Old May 7, 2007 | 01:43 PM
sauceja's Avatar
If this is an ls motor just get a vtec head and your good.
Maybe he is telling you the head is shot so you will sell the motor to him cheaper? Just a thought.
Old May 8, 2007 | 01:55 PM
krazeenoy's Avatar
Default Re: (sauceja)
went to chek it out....when i try to start it..it just cranks....but it doesnt start...anyone have an idea whats wrong with it?...i tried to do the timing but he didnt have much time....maybe the timings off or the distributer not working?
Old May 8, 2007 | 02:09 PM
Rice-aronie's Avatar
compression test...
Old May 8, 2007 | 08:22 PM
krazeenoy's Avatar
i cant really test anything until i buy the car....my friend says it mite be the timing....but i dont wanna take a risk on it...unless i get more ideas of mite what be wrong with the motor....the timing belt looked like it was kind of messed up..it was like peeling off the side like little strings of it a little...i popped the valve cover open...the head still clean just dont really know whats wrong with it....
Modified by krazeenoy at 11:23 PM 5/8/2007
Old May 9, 2007 | 06:28 PM
Bonestock98GS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazeenoy &raquo;</TD></TR><TR><TD CLASS="quote">went to chek it out....when i try to start it..it just cranks....but it doesnt start...anyone have an idea whats wrong with it?...i tried to do the timing but he didnt have much time....maybe the timings off or the distributer not working?</TD></TR></TABLE> Ok I maybe wrong but anyone who knows can correct me. How many miles does the mototr hae becuz usually at about 115,XXX miles that calls for a timing belt change. I know that from experience and I was one of THE LUCKY GUYS who timing belt went bad and didnt have any bent valves. From it turning over it could be ur dizzy but I wouldnt recommend turning it over too much cuz that will surely bend the vales if not already bent. Now if it has over the alotted lilage due for a timing belt then thats what it is. Timing belt. Like I said crrect me if I am wrong just going from what happened with my engine.
Old May 9, 2007 | 08:46 PM
blakacintegra's Avatar
Default Re: (Bonestock98GS)
new motor
Old May 9, 2007 | 09:24 PM
lazyxmofo's Avatar
should be working fine...just try to replace the timing belt....
Old May 9, 2007 | 09:29 PM
krazeenoy's Avatar
it has 113,000 miles on it still low...imma get it tomrrow...gonna check it out...for the people who says new motor...i dont think it needs a new motor...it cranks...but it just doesnt start....
Old May 10, 2007 | 04:47 AM
Yea you are right man if it turns over its not needing a new motor. Its either the dizzy or the timing belt. Good luck and I hope she gets up and running
Old May 10, 2007 | 09:20 AM
94lspower's Avatar
There is barely a chance that u didnt bend a valve or more, if the timing belt breaks at a speed u probably bent a valve. It happened to me on a saab 9000 turbo and i was going about 60
Old May 10, 2007 | 05:34 PM
Default Re: car problems (94lspower)
Well 94lspower I was pullin out of work to go to lunch and I didnt bend a valve took everything apart and checked . When I went to go to 2nd gear it just cut off I thought I might have stalled out but timing belt was the issue.
