B16 Built Motor 84mm with built gs-r head
Old May 6, 2007 | 03:02 PM
Black DC2's Avatar
Default B16 Built Motor 84mm with built gs-r head
I NEED A 99-00 gs-r motor.. I will do a trade plus cash deal. Also turbo kit IS NOT included, this deal is for the MOTOR only!!!!
Fully Built B18C1 motor. Built by ERL....
B16 ERL Superdeck 2
84.mm Final Bore.
84.mm JE 9 to 1 Pistons
Crower Pro Billet Rods
motor has ARP HEAD STUDS and ARP main bolts.
ACL RACE Bearings
GSR Oil pump.
New HONDA front and rear main seals
GE 84mm Headgasket
Entire assembly balanced and blueprinted
New Timing belt and waterpump and thermostat.
New water hoses for the water to oil oil cooler.
New Stock Honda Oil pan.
Now for the Head,
GSR Head fully done
skunk2 Dual Valve Springs
Titanium Retainers
Ferreria SS stock size Valves
type r Cams, new cam seals, skunk2 cam gears
The entire motor was run for 1000miles before being boosted. Breaking in tune done by MASE.
2000miles on motor with turbo kit installed with full tune done my MASE, oil and filter changed out every 800 miles. Compression is 195 PSI across all cylinders. Does not smoke idles perfectly.
Motor is still in the car and running this is my daily driver as i need some way to get around. Motor runs great N/A.
$6000 shipped. Motor will be sent via YELLOW Freight.
I will condiser a trade for a Stock 99-00 gs-r long block plus 4000.00 cash
DYNO SHEET
http://www.masetuning.com/Tune...3.jpg
Old May 6, 2007 | 05:11 PM
Black DC2's Avatar
Default Re: B16 Built Motor 84mm with built gs-r head (Black DC2)
ttt
Old May 7, 2007 | 05:54 PM
Black DC2's Avatar
ttt
Old May 8, 2007 | 06:10 AM
Mr.OB*GYN_Rhett's Avatar
wowzas
Old May 8, 2007 | 05:37 PM
Black DC2's Avatar
Default Re: B16 Built Motor 84mm with built gs-r head (Mr.OB*GYN_Rhett)
yes sir
MyLilCivic
Sep 20, 2013 04:53 AM
Black DC2
Jun 7, 2007 03:34 PM
Bulldogg83
Jun 7, 2005 09:36 AM
Bulldogg83
May 20, 2005 08:27 AM
