Tweeter Location In a 1997 Accord SE
Old May 30, 2002 | 05:27 PM
Blockhead G's Avatar
Default Tweeter Location In a 1997 Accord SE
I've been fighting with this for quite some time now ... I want to put my tweeter up high on the doors, but I don't want to cut the door panel to do it ... I did that in my last car, and I had to let those tweeters go with the car .
I would like to put them on that trianglgular plastic piece covering the connections to the power (side) mirrors, but I'm afraind that they will look like a tumor - Ew!
Anyone have some suggestions?! Pics would be nice
Old May 30, 2002 | 05:30 PM
p0pe's Avatar
Default Re: Tweeter Location In a 1997 Accord SE (Blockhead G)
I think you'll get more replies in the audio forum...
Old May 30, 2002 | 05:36 PM
Sorry Dude! I didn't know that this was restricted to some other topic - It IS for an Accord. Exqueeze me.
Old May 30, 2002 | 05:37 PM
p0pe's Avatar
I'm not flaming on you... just letting you know in advance
Old May 30, 2002 | 05:41 PM
Default Re: Tweeter Location In a 1997 Accord SE (p0pe)
Point taken - Good Advice ... done that too
Cheers!
Any pics?!
Old May 30, 2002 | 05:56 PM
bmm89's Avatar
i did the same thing, it's a good idea, actually mine is an ex with stock tweets, but i just disconnected them. Location is actually very nice there, although a little bright due to proximity
i'll post a pic if i can find it...
Old May 30, 2002 | 06:30 PM
Kazmans94cord's Avatar
i installed my tweeters right next to my door locks and handles...i like it there...it looks very clean too...i dont have any pics..but ill try....
Old Jun 1, 2002 | 06:30 PM
Default Re: Tweeter Location In a 1997 Accord SE (bmm89)
What year Accord do you (bmm89) have? If you can find ANY pics of stock tweeters for the Accords in that triangular location by the side-view mirror, please email me ... GMan_CRX@Hotmail.com
Cheers
Old Jun 1, 2002 | 08:49 PM
bmm89's Avatar
97 same as you, i have an ex, with stock tweets in the dash next to window... they are now disconnected, using infinity kappas(y2k version) components
Old Jun 2, 2002 | 07:17 PM
-RedneckDave-'s Avatar
Working
if you know a place that installs stereo stuf then take it there, but personally i would take the piece out and either flush mount thetweeter your self or use the external piece that comes with them cause normally they only screw in and do not take a genius to install. ON the other hand you could try your hand a doing fiberglass work and build a set of kick panels in the corners of youe floorboard and get better sound imaging
Old Jun 3, 2002 | 06:37 PM
bmm89's Avatar
Old Jun 3, 2002 | 08:01 PM
Sweet! Thanks man!! If you RIGHT CLICK on the "Oops thing" go to "Properties" and copy / paste that into a new browser, the image will be able to be seen.
Looks like I might have to do some fiberglass work
Old Jun 3, 2002 | 08:30 PM
bmm89's Avatar
there was no fiberglass work involved, i just flush mounted the tweeters without the adjustable pods using stock triangles
pulled the triangles off, then drilled a hole in them for wires, then i think i glued the tweeters on, or maybe they had screws, eitherway works
wiring goes behind the panel which you can kinda see here:
i have components but separates is the same setup
oh and to get the triangles off, you have to pull OUT then UP and for the doors, one screw behind plastic cover in door latch, another at the bottom of the door pull, and one plastic cap that just pops off just below the triangles
then remove door latch panel by SLIDING towards the front of the car, sorta like battery cover on remote, cuz there are two plastic hinges behind the plastic panel
then push the plastic clip away from the door pull lever, remove wiring, lift up the door and out
it's self explanatory once you get the screws out... just do not pull straight out on the door latch panel, the stupid hinges will break!!! honda wants $150 for each of those mothers so don't break them... i learned the hard way(buy superglue just in case)
Old Jun 3, 2002 | 08:59 PM
CD8's Avatar
CD8
wow... look at all that extra weight.
teg_dc2
Acura TL, RL & ZDX
29
Jul 10, 2008 08:41 AM
platinum princess
Apr 11, 2005 02:49 PM
PSU
Aug 5, 2003 12:14 AM
