Bore Size, Fitment Help (jdm To Uk)
Old May 6, 2007 | 07:05 AM
zeromx's Avatar
Default Bore Size, Fitment Help (jdm To Uk)
Hi all,
If you got a B16 with JDM 2.5" Bore manifold is there any way to connect it to a OEM 2.25" system, with a 2.25" decat?..
Old May 6, 2007 | 07:06 AM
Padawan's Avatar
Darth ModerVader
Default Re: Bore Size, Fitment Help (zeromx)
You can use either a 2.5" decat, or a custom 2.5" high-flow cat (which is what I'd recommend).
Old May 6, 2007 | 07:12 AM
zeromx's Avatar
but wouldnt de-cat 2.5" be too big for the 2.25 system?
Old May 6, 2007 | 07:20 AM
Padawan's Avatar
Darth ModerVader
Default Re: (zeromx)
It won't be too large because the actual flange that bolts to the exhaust is the same overall size and same bolt pattern. The difference is only in the size of the inner bore itself.
Old May 6, 2007 | 11:25 AM
doood's Avatar
been there done that
you can weld a 2.5'' flange onto whatever exhaust you're using
eg6_vti93
Oct 19, 2012 02:28 PM
s0ulless
Oct 12, 2004 05:11 PM
Unjockable
Apr 6, 2003 11:19 PM
cruzersi99
Oct 15, 2002 11:49 AM
