what size injectors?
hey i was just wondering on what size injectors i will need..i have ctr pistons with eagle rods, ported head with jun stage 2 cams, and the bolt ons 2...any help would be ncie
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_motaUSA »</TD></TR><TR><TD CLASS="quote">370cc ..... those injectors will hold up almost anything a n/a b-series can throw at it </TD></TR></TABLE>
yeah i have these tooooo
im guessin youre just a little bit bigger than stock bore of course..but on a good tune, and an i/h/e already on(i assume as well), i'd say betw/205-215whp...my car put down 195 corrected whp on a stock bottom end, i/h/e, skunk2 pro 1 cams and also being on stock injectors!.... awesome setup btw, ive got my motor out and workin on something similar to yours!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chump2825 »</TD></TR><TR><TD CLASS="quote">would i have to change my fuel pump? ctr pistons in itr compression is high nd with jun stage 2 i should be alot higher then 215</TD></TR></TABLE>
be grateful if you break 200whp. 215whp with stock bore is no joke and not done lightly.
the stock pump is also sufficient.
yes sir...you can either go with a walboro(spelling) 190 fuel pump or go bigger and go with a 255(which in my eyes, i think, is overkill)
See Are X
Dec 14, 2005 07:29 AM
B18cHatch06
Jan 29, 2005 11:05 AM
