Transmission Rebuild Kit for 95 Integra GSR
Hey guys i have a 95 Integra gsr tranmission that needs to be rebuilt. What is a good company that sells these kits, where can i get them, and how much do these rebuild kits usually cost? TIA
There is no transmission rebuild kit.
You will need to inspect the parts. Synchro sleeves, bearings, and the clutch teeth on each gear for wear. Unfortunately, you are going to end up spending a fortune on replacement OEM parts.
Gearspeed sells carbon layered replacement synchros.
Don't forget new seals and check the thrust clearances on the input/output shaft per Helms spec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">There is no transmission rebuild kit.
Don't forget new seals and check the thrust clearances on the input/output shaft per Helms spec.</TD></TR></TABLE>
Thanks. Well that sucks i'm pretty lazy.
I have to evaluate everything on a case-by-case basis because most people don't have $1000 to $1500 to replace every single bearing, seal, synchro set, and other misc parts.
I've had one guy spend over $1000 just on parts to replace two shift forks, all three synchro sets, all but one of the bearings, one seal, and convert it to a LS 5th gear.
All of the other rebuilds/LSdinstalls have been between $125 to $500 (aftermarket parts not included).
yea well im on the same problem about fixing my tranny too... i already know that its going to cost a fortune so im just waiting to get all the parts including the jdm final drive, lsd, stage 3 clutch and etc. so if u know that your to do more on your tranny then just get it over with now... dats my opinion
auto zone sells "rebuild" kits for the gsr tranny it comes with bearings syncros and seals that all and retails somewhere around $620 im rebuilding one this week with a buddy should have pics up of the process and some how to's for those who are first timers lookin to score some tranny action and i dont mean chicks with ...uhh nevermind
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxt5r1 »</TD></TR><TR><TD CLASS="quote">auto zone sells "rebuild" kits for the gsr tranny it comes with bearings syncros and seals that all and retails somewhere around $620 im rebuilding one this week with a buddy should have pics up of the process and some how to's for those who are first timers lookin to score some tranny action and i dont mean chicks with ...uhh nevermind</TD></TR></TABLE>
i wouyd like to know how that goes, because i know autozone cant touch factory quality....good luck though cuz if it seems goos may to it to my tranny..
are though gearspeed synchros better than factory?? tell me about them and about how much a set cost...or a website a i can look them up at.
1995, carbon, cost, gsr, integra, kit, rebuild, rebuilt, replacement, synchro, synchros, tranmission, tranny, transmission, trasmission
