mount problems
Old May 5, 2007 | 02:31 PM
CornerCarvin's Avatar
Default mount problems
I just dropped my LS motor into my Si, bolted up the driverside and tranny mount and found a problem. the front mount and the rear motor mount arent even close to lining up. here are a few pics of what i am talking about.
http://viewmorepics.myspace.co...87774
any help is appreciated
Old May 5, 2007 | 03:00 PM
crxnj's Avatar
Default Re: mount problems (CornerCarvin)
are those stock ls mounts?
Old May 5, 2007 | 04:02 PM
Default Re: mount problems (crxnj)
No they are supposed to be d to b-series mounts but I have yet to find any like them on the web. The drivers side and trans mount fit fine but the front and rear mounts are about an inch or 2 off.
The guy I bought the car from sold the mounts and linkage with it and there was an Enjo sticker on the window so I figured thats what they were, but I'm guessing that the linkage is enjo and the mounts are a different brand.
Old May 5, 2007 | 06:47 PM
bigwormb16a's Avatar
get the HASPORT or a cheaper mount kit you dont use that front mount,just the rear and sides
Old May 5, 2007 | 06:53 PM
STREETWERKZ's Avatar
Default Re: mount problems (bigwormb16a)
jack the motor back up, loosen the mounts a lot. you have the bolts too tight right now.
keep trying, they will work. ive had mounts further off than that and they still fit.
Old May 6, 2007 | 09:01 AM
Default Re: mount problems (STREETWERKZ)
Are you talking about the bolts that mount to the car or the motor? i still dont think there is enough play to move the motor that much. plus it is really hard to get a wrench or a socket on the bolts once everything is in place, especially on the rear mount.
preludeNApower
Jan 12, 2012 08:35 AM
efyou
Apr 23, 2008 03:59 PM
Del Sol on Steroids
Apr 13, 2007 04:23 PM
Maengelito
16
Dec 5, 2004 07:07 AM
Brewer
Mar 23, 2004 07:30 PM
