could a bad axle cause a front end vibration?
Old May 5, 2007 | 01:30 PM
projectek's Avatar
Default could a bad axle cause a front end vibration?
could a bad axle cause front end vibration? I had a B16 swapped into my ek about 6 months ago. Now when I accelerate I get a vibration from the passenger side. I'm sure my rims are straight and it's not a balance issue. I have checked all the bolts and motor mounts and everything looks good. I have even jacked the car up and wiggled the wheel to check for any play and nothing. Sometimes when I take turns around 40mph (nothing crazy just normal daily driving) I get a jerking feeling that seems to come from that same side and can be felt in the steering wheel.
Old May 5, 2007 | 01:34 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: could a bad axle cause a front end vibration? (projectek)
yes...its happened to me before..but that may not be the problem in your case..what about your tires are they separating..chopped??
Old May 5, 2007 | 01:38 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: could a bad axle cause a front end vibration? (Throwdown)
Could be the tires, endlinks, bearings, or axles.
Old May 5, 2007 | 02:17 PM
projectek's Avatar
Default Re: could a bad axle cause a front end vibration? (ek forever guy)
tires are in really good shape. I'm pretty sure I just got **** axles with my swap and just covering my bases before I start replacing stuff.
Old May 5, 2007 | 02:20 PM
c1v1c98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectek &raquo;</TD></TR><TR><TD CLASS="quote">tires are in really good shape. I'm pretty sure I just got **** axles with my swap and just covering my bases before I start replacing stuff.</TD></TR></TABLE>
Yea, I'd replace the axles that came with the swap. Whether they appear to be bad or not.
See Are X
Apr 17, 2006 02:44 PM
Takumi Fujiwara
Feb 25, 2004 09:17 AM
DEVIN22CBR
49
Jan 4, 2004 01:32 PM
ebelp
Nov 28, 2003 10:34 AM
wdyno
Apr 16, 2002 11:13 AM
