Changing manual Trans Fluid 2005 Accord
Old May 5, 2007 | 12:59 PM
Gocauo's Avatar
Default Changing manual Trans Fluid 2005 Accord
Hey folks!!
I tried looking around for an answer before posting, but I am not having much luck.
I think I found the drain bolt (3/8" ratchet) and the fill bolt just above and to the right of the draing bolt. But this is all on the driver's side, and not the passenger's side like it states in other posts.
Are these the two bolts I am looking for?
thanks!!
Old May 5, 2007 | 05:40 PM
hondadude's Avatar
Default Re: Changing manual Trans Fluid 2005 Accord (Gocauo)
Yes the drain plug has a 3/8 square hole in it #10 in the pic;
And the fill bolt should be a 17mm above the axle inner CV joint #15 in the pic.
The Pic is a 4 cyl.
Old May 6, 2007 | 03:34 AM
Gocauo's Avatar
Default Re: Changing manual Trans Fluid 2005 Accord (hondadude)
Thanks hondadude!
I thought those might be it given the description given in these forums, but seeing as how they were on the driver's side and not passernger side, I wanted to be sure I was not missing anything.
Now it's off to replace the fluid!!
Old May 7, 2007 | 04:33 AM
TouringAccord's Avatar
H-T Order of Merit
assuming you have a four cylinder the K series engine rotates the opposite way so the engine is flipped around in the engine bay from the previous generation Accords. So your transmission would now be on the driver side instead of on the passenger side like you were reading in other posts, those other posts were most likely in reference to a 90-02 Accord.
Old May 7, 2007 | 12:45 PM
JimBlake's Avatar
Default Re: Changing manual Trans Fluid 2005 Accord (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">... those other posts were most likely in reference to a 90-02 Accord.</TD></TR></TABLE>Another FINE example of why it's important to be aware of what year & model we're all talking about.
The 4-cylinder Accords flipped the engine around to the opposite side, beginning in 2003 with the K-series engines. The V-6 Accords have already flipped around, beginning when? 1995?
rollercosta123
Jan 16, 2021 01:10 PM
blk600cc13
34
Apr 10, 2020 04:56 AM
!!miguel!!
May 4, 2010 10:56 PM
Slammd Sol
Mar 28, 2004 10:21 AM
NZ Vtec Weapon
Mar 23, 2003 12:28 AM
