+++++POWER WINDOW CONVERSION ON EK HELP++++
Old May 5, 2007 | 12:00 PM
jjrek9's Avatar
Default +++++POWER WINDOW CONVERSION ON EK HELP++++
i just did my power window conversion on my 97DX hatch and did the climate control conversion well i was at it. the climate control conversion came out fine but the power windows is another story. i have no power coming out to the window harnesses on each side and when i turn on my lights the cluster and climate control dont light up although the climate control is working properly except for no lights. i did use a floor harness for this swap from a 98EX. checked my grounds, fuses, relays, plugs, even unplugged the fuse box and conected everything up again but still nothing. i did use this write up for the swap
https://honda-tech.com/zerothread?id=922683 and this one for the climate control swap
https://honda-tech.com/zerothread?id=605432. even did the rear wiper thing and that came out fine. also when i first plugged my battery back to test things out a long beep came from inside the car like when you forget to turn your lights off. i unplugged the bat. thinking what the heck check things out and it beeped again but stoped after about 4 seconds. well if anyone can help me out to what other things i can check out to so i can get things working i would Appreciate it. i have searched but found nothing that can help me. please keep negative comments to yourself
Old May 5, 2007 | 11:28 PM
jjrek9's Avatar
Default Re: +++++POWER WINDOW CONVERSION ON EK HELP++++ (jjrek9)
anyone
Old May 6, 2007 | 01:19 PM
jjrek9's Avatar
Old May 6, 2007 | 03:27 PM
hatch96y7's Avatar
did u swap out ur doors or just put in the regulators
Old May 6, 2007 | 04:02 PM
vtecftw's Avatar
fuse
Old May 6, 2007 | 04:54 PM
jjrek9's Avatar
Default Re: (vtecftw)
just put in the regulators and checked the fuse's but no luck
Old May 6, 2007 | 04:55 PM
jjrek9's Avatar
Default Re: (jjrek9)
hope its not a bad floor harness
Old May 7, 2007 | 05:17 PM
jjrek9's Avatar
Old May 8, 2007 | 03:49 PM
jjrek9's Avatar
bump
Old May 8, 2007 | 04:14 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
pm'ed
Old May 8, 2007 | 05:24 PM
RA61825's Avatar
damnjives ya te chingastes
Old May 8, 2007 | 10:17 PM
jjrek9's Avatar
nah it will get fixed
Old May 10, 2007 | 10:31 AM
marshun's Avatar
double checked all the wires and made sure they go somewhere? that was my problem when i did mine a long time ago
Old May 10, 2007 | 01:52 PM
jjrek9's Avatar
Default Re: +++++POWER WINDOW CONVERSION ON EK HELP++++ (marshun)
maxxedsx
Mar 8, 2006 06:01 AM
