Oxidation Repair
Old May 5, 2007 | 07:51 AM
Skipper75's Avatar
Default Oxidation Repair
What products/techniques would work well to remove heavy oxidation spots on auto paint?
Old May 5, 2007 | 10:05 AM
E-Rok's Avatar
EPIC TUNING
Default Re: Oxidation Repair (Skipper75)
I use Meguairs Power Compound + a yellow foam pad and my Milwaukee rotary. followed by Meguiars Swirl-Free Polish on a white pad. then wax.
Old May 5, 2007 | 01:31 PM
Skipper75's Avatar
Default Re: Oxidation Repair (E-Rok)
aye sounds good...thanks
Old May 5, 2007 | 07:33 PM
Skipper75's Avatar
dang my oxidation is so bad that rubbing compounds are not taking it out.i can chip it off with a scraper..hehe
i think i'm gonna look for some ultra fine sand paper and gently scrape/rub it off.
what do you guys think and where should i get the paper i would need?
Old May 5, 2007 | 09:04 PM
LastDetail's Avatar
If you can scrape it off then there is something else working on your paint here. If it is chipping off it sounds like it might be some serious clear coat failure. Do you have any pictures of the damaged areas?
I would try using Klasse AIO, usually this stuff kicks *** on oxidized paint.
If you want a sanding recomendation I would say the heaviest you would want to go is 1500 grit. Follow it up with 2000 and then maybe even 2500 or 3000. My favorite is UniGrit from Meguiars.
Just remember though polish takes off some of the clear, sanding takes off a WHOLE LOTTA clear, so if you screw up there is pretty much no correcting it without painting.
Can you post a picture?
Old May 6, 2007 | 02:49 AM
e2000's Avatar
I believe he has clear coat failure too..I would like to know if you can do any for it?
Old May 6, 2007 | 05:39 AM
E-Rok's Avatar
EPIC TUNING
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skipper75 &raquo;</TD></TR><TR><TD CLASS="quote">dang my oxidation is so bad that rubbing compounds are not taking it out.i can chip it off with a scraper..hehe
what do you guys think and where should i get the paper i would need?</TD></TR></TABLE>
your paint is probably fucked then.
Old May 6, 2007 | 05:44 AM
Skipper75's Avatar
yeah the paint is in bad shape in some areas...i was just trying to salvage it till i can save up for a paint job.
thanks for all your guys info
Old May 6, 2007 | 05:50 AM
E-Rok's Avatar
EPIC TUNING
well, heres what i did to my hatch which has severe clearcoat failure.
Before:
Some of my ****:
Before and After:
as you can see, it didnt really do much for the oxidized clearcoat, but the rest shined up pretty good. i could have sanded it off but why bother, the car is a beater.
Old May 6, 2007 | 06:40 AM
Skipper75's Avatar
hehe.. yeah thats what is going on with my paint
Old May 6, 2007 | 08:09 AM
E-Rok's Avatar
EPIC TUNING
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skipper75 &raquo;</TD></TR><TR><TD CLASS="quote">hehe.. yeah thats what is going on with my paint
yea its pretty much done. you could probably sand the oxidized clearcoat off, but its not worth it IMO. just get it repainted. I will say my paint looks ALOT better after I compounded it, even with the messed up clearcoat.
Old May 6, 2007 | 12:11 PM
LastDetail's Avatar
Yeah I agree with E-Rok, if that is what your paint looks like then it is most definately clear coat failure and there is really no fix for it other than a repaint. Sorry man thats a bummer
Old May 8, 2007 | 08:37 AM
Skipper75's Avatar
Default Re: Oxidation Repair (LastDetail)
i tried rubbing compounds and 1600 grit sandpaper and this stuff wont go away!
lol i guess it looks a little better...i'm tempted to go and buy some spray paint and just cover it up.
what paint would look the most like my stock black crx paint you think..in a spraycan and where could i find it?
just a temp fix not trying to win shows
Old May 8, 2007 | 06:31 PM
Hella_Fresh's Avatar
http://www.paintscratch.com
Old May 9, 2007 | 09:43 AM
Automations's Avatar
Default Re: Oxidation Repair (sXekid)
sanding and buffing will not fix that problem it needs paint
Old May 9, 2007 | 12:59 PM
Default Re: Oxidation Repair (Automations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Automations &raquo;</TD></TR><TR><TD CLASS="quote">sanding and buffing will not fix that problem it needs paint </TD></TR></TABLE>
good to know cause i have the same problem. figured i was going to re spray it anyways
Pacific Rider
Paint and Body
Apr 17, 2011 10:43 AM
PolishSasquatch
Paint and Body
12
Aug 8, 2009 11:12 AM
i love my ef
Apr 9, 2006 08:03 PM
FlipboiGSR
Aug 15, 2003 10:13 AM
Rydaddy
Jul 21, 2003 12:06 PM
