Fixing Tail Light Seal
Old May 5, 2007 | 04:48 AM
g2tegsown's Avatar
Default Fixing Tail Light Seal
I bought a set of tailights on ebay and one of them has a leak in the seal, does anyone know of a good sealant to fix this?
Old May 5, 2007 | 02:09 PM
NOFX's Avatar
H-T White Ops
https://honda-tech.com/zerothread?id=885253
Old May 5, 2007 | 06:24 PM
g2tegsown's Avatar
That was a sweet tutorial, however I don't mean the gasket I mean the whole tail light assembly. It's kinda 2 parts, and my upper right corner is leaking.
Old May 15, 2007 | 01:46 PM
E-Money's Avatar
Default Re: (g2tegsown)
same prob, can i just reseal the whole assembly with some silicone rubber sealant on the gasket part?
Old May 16, 2007 | 11:51 AM
WihaSi's Avatar
Default Re: (E-Money)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Money &raquo;</TD></TR><TR><TD CLASS="quote">same prob, can i just reseal the whole assembly with some silicone rubber sealant on the gasket part?</TD></TR></TABLE>
I would go with some silicone. Make sure to get all the moisture out of the tail lamp before sealing it.
Old May 16, 2007 | 01:33 PM
E-Money's Avatar
Default Re: (WihaSi)
yea i was thinking about some GE sealant i have at work. its used for window and door seals so i figured it would be good to use. i plan to bake the tail lights at like 180 degress for like 10 minutes. if anyone can chime in about baking the taillights....
Old May 16, 2007 | 06:49 PM
g2tegsown's Avatar
I did mine with some plain old clear silicone, I used a rubber clamp to hold it together well it dried, worked like a charm. The only drawback was I went a little to tight with the clamp and cracked my tail light But I just bought a new set off a CRX that had only 10,000 mi that had a front end collison, they are incredible
hpimichael02
Sep 2, 2008 09:32 PM
TehMoonRulz
22
Apr 22, 2006 04:16 PM
IntegraBoy04
Feb 9, 2004 07:51 PM
redteg1
Apr 14, 2003 04:57 PM
VTECAcuraGSR
Mar 17, 2002 11:55 AM
