Integra dash and door panes in an EG
Hey Ive searched to see if the dash would fit so i know that would but what about the door panels and if soo get me a DIY thread o
n it thank you
n it thank you
i have the in teg dash in my car it fits great you have to trim your center air vent down once your dash comes out inorder for the teg dash to fit them u can cut your door panels or to fit the integras u have to flip it over and the part that hangs on the door edge you have to cut out the ribs under it so the door panel will go far enough down to reach the bottom of the door , but the teg trim panels are half an inch short on the back side u will see some of the frame of the door when it is closed form the back seat
i have a teg dash in my eg and you definatly dont have to cut any of the duct tor the center vents unless you want it to be done getto!!!
you need to take the top section of the heater box off of your civic and take swap it with the one off of the integra then the dash will bolt straight on you will need to use the teg side mount brackets too as far as the door pannels just leave your foctory one on the door then with the dash installed pull the door to the dash and take a sharpie marker and trace around the dash edge onto the door i used a dremel to cut mine
Orangeciv
11
Jan 7, 2010 09:32 AM
BlackAlbumKoupe
Nov 5, 2009 05:25 PM
MikeyDB7
Jun 9, 2003 03:44 PM
