car wont start afte.......HELP
i just did a new headgasket and a peakboost turbo kit.... i went to start the car for the first time and it dont start, continues to turn but wont start.....HELP pleeze
check all your sensors and wiring. then check ur distributor and make sure u have the plugs in order. also check ur fuel filter. my buddy just did a b16 swap and it wouldnt start so I had to go over the whole car and all it ended up being was the filter. its was so gunked up inside I didnt see how it was even gettin a little fuel. But u got it easy. At least it turns over so now check ur whole fuel system one by one then ur spark. also make sure ur cars timing is correct too.
check all your grounds, usually the one on top of the thermostat housing, then check the computer, see what codes is showing if any. if the timing was off you should be able to hear the diffrence when cranking the car. if the wires were wrong it should backfire or hesitate to start and wana turn the wrong way.
yea so i would like to update everyone, and the problem is, the guy that chipped/socketed my ECU did it wrong, because i tried my buddies and it fires and runs just runs cruddy cus its got 4000cc injectors compared ot my 450s....and if i let mine reset it fires and then slowly dies.....so thanks for the help...and i came down to the problem...
[QUOTE=honduh8993]yea so i would like to update everyone, and the problem is, the guy that chipped/socketed my ECU did it wrong, because i tried my buddies and it fires and runs just runs cruddy cus its got 4000cc injectors compared ot my 450s....and if i let mine reset it fires and then slowly dies.....so thanks for the help...and i came down to the problem...[/QUOTE
4000 CC injectors??
typo much?
4000 CC injectors??
typo much?
boobie1721
10
Dec 18, 2007 03:56 AM
sipolt89
Dec 9, 2007 10:14 AM
