painted lip, now it looks wrinkly..
I painted my front lip on my car and the paint doesnt look so smooth. I put about 4 coats of paint and the paint looks kind of wrinkly when you look at it closely. Is there any way to smoothen it out with a buffer before i clear coat it? Im not trying to sand all the paint off and start over again, lmk
Its a carbon fiber chargespeed replica front lip for a 99-00 civic. I used rattle can paint Duplicolor Silver (m)..it matches perfectly with vsm. I'm assuming i was spraying too far which made it look a little wrinkly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dinko »</TD></TR><TR><TD CLASS="quote">how bout...no primerrrrr </TD></TR></TABLE> hehe yep
90% of painters problems have to do with prepwork.
if you want it done right, sand it down, prime it, THEN paint it.
My guess would be that maybe you laid it on a little too thick and didn't let it dry enough between coats? I've done that on random things before and it results in the prune-finger effect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKidd »</TD></TR><TR><TD CLASS="quote">good looking out
ill be waiting for the pic
You are suppose to post the pic of your paint lip
</TD></TR></TABLE>You are suppose to post the pic of your paint lip
Quick question to the OP, how was the weather when you painted.
I got impatient the first time I painted and did it when it was about to rain. Got those wrinkles that you might be talking about.
Also I used that silver before, but it turned out a little darker after i sprayed the clearcoat. I switched to Krylon Silver Metallic 1406.
check this out:
https://honda-tech.com/zero...age=1
check this out:
