6th gen auto to manual (specific question)
Old May 4, 2007 | 03:54 PM
skingfreak's Avatar
Default 6th gen auto to manual (specific question)
Ive been looking into getting a 6spd swap done on my 2000 accord coupe ex v6. I have been have trouble finding an exact parts list. Would i need all of these parts?
(i copied and pasted this list from the accord FAQ, so dont mind the year of parts the cars are coming out of)
1. 5 speed transmission (F22, F23, H22, H23)
2. 5 speed starter (90-02 Accord 92-02 Prelude)
3. 5 speed shifter assembly w/ shifter cables (90-97 Accord, 92-96 Prelude)
4. 5 speed drivers side axle (your year accord, but from 5-spd version)
5. 5 speed intermediate shaft (your year accord, but from 5-spd version)
6. 5 speed clutch pedal assembly (90-97 Accord, 92-96 Prelude)
7. 5 speed brake pedal arm (90-93 Accord, 94-97 Accord)
8. Clutch master cylinder w/ reservoir and lines (90-97 Accord 92-96 Prelude)
9. Clutch line from Clutch master cylinder to clutch dampener (90-97 Accord 92-96 Prelude)
10. Clutch dampener assembly (90-97 Accord 92-96 Prelude)
11. Clutch line from Clutch dampener to 5 speed tranny (90-97 Accord 92-96 Prelude)
12. Clutch line from 5 speed tranny to slave cylinder (90-97 Accord 92-96 Prelude)
13. Slave cylinder (90-97 Accord 92-96 Prelude)
14. Clutch (90-02 Accord 92-01 Prelude)
15. Flywheel (90-02 Accord 92-01 Prelude)
16. 5 speed mount (Your year, 5-spd version)
17. 5 speed mount bracket (go to Honda - tell them to look for the bracket that is welded on the car - part is S.O.P and costs 15-25.00) (see notes)
18. MIG WELDER (see notes)
19. BOLTS: 8 Flywheel Bolts, 6 Pressure Plate Bolts, 3 Intermediate Shaft Bolts, 1 Long Tranny Bolt
20. Recommended: HELMS Service Manual (http://www.helminc.com)
I also found this part list, this one is closer, but im still not sure.
Engine. J32A2 If needing a new engine look for a CLs-6 motor (if not see below *)
03 CLs-6 speed manual.
03 CLs-6 Manual Engine Harness. 32110-PGE-A11
03 CLs 6 speed ECU
03 CLs-6 Flywheel 22105-PGE-305
03 CLs-6 Flywheel bolts (Qty 8) 90011-PGE-000
03 CLs-6 Clutch Assembly 22105-PGE-305 (unfortunately right now there arent many options for aftermarket clutches) Spec sells a full line of clutches and flywheels now.
03 CLs-6 Rear Engine mount and bracket 50810-S3M-A01, 50827-S3M-A00, BOLT (m12X25) 90166-S3M-A00 The stock mounts work but they will not last forever due to the additional power and torque
03 CLs-6 Rear and Front Engine Dampener and bracket (i would reccomend aftermarket here) There are no aftermarket applications that I know of but there are custom solutions
03 CLs-6 Shifter and cables. 54100-S3M-A01, 54310-S3M-A01 The 6th gen accord shifter assembly works fine and bolts right in. I used that and a custom boot for mine.
03 CLs-6 Starter 31200-PGE-A11 (try to locate used, its expensive)
03 CLs-6 Gauges Not required. The factory gauges work just fine
03 CLs-6 Hydraulic Clutch lines. 46960-S3M-A01, & 46970-S3M-A01
03 CLs-6 Trans mounts (2 of them) 50806-S3M-A03, 50805-S3M-A03 There is also a third part to the mounts that the mounts actually bolt to since they don't bolt directly to the trans.
03 CLs-6 Cup Holder 77230-S3M-A01ZA Not required. The automatic one can be used
03 CLs-6 Parking brake 47105-S3M-A04ZA and to go with it, Not needed either
Spring 47537-671-670, Nut 47522-594-000, Equalizer pin 47365-538-000, Equalizer 47360-SB2-000
*If you use the J32A2 from the Auto you will need these parts (all from the CLs-6)
Front cam pulley 14260-PGE-A11
Front plate assembly (behind cam pulley) 11860-PGE-A10
Timing belt pulley(lower) 13621-PGE-A11
Crank shaft sensor 37500-PGE-A11 (this little **** costs $500.00)
Subharness for CKP 37501-PGE-A10
TDC Sensors (Qty 2) 37840-PGE-A11
TDC SUB HARNESS 37841-PGE-A10
Which parts do you think are needed? Im not looking for someone to walk me through the swap, but i would like some feedback on the parts needed. (this will be profesinally installed, but i would like to source the parts myself to save some $$$)
Old May 4, 2007 | 05:16 PM
Loco-B's Avatar
Default Re: 6th gen auto to manual (skingfreak)
wow that looks like a lot of pointless info....
by that time, you could have taken it to your local dealership and put all that money down on a vehicle with a 6speed in it.
IMO waste of time and money. i wouldnt do it.
Old May 4, 2007 | 08:34 PM
skingfreak's Avatar
Default Re: 6th gen auto to manual (accordcd_7)
Not to be an ***, but i didnt ask whether this was a waste of time and money, i asked what parts were needed to complete the project. And since im going to college next year, i need a car with a reliable tranny in it, and i will not be able to afford a car payment, but i can however afford to do this, so thanks for your input, but if you dont have something constructive to say about this project, please keep it to yourself
sony224422
Dec 13, 2007 08:05 AM
sony224422
Northeast (Sales)
Dec 12, 2007 03:05 AM
flight50
Nov 3, 2005 09:17 AM
Accord_Kid
Jan 25, 2005 06:11 PM
