motor trouble NEED help FAST
Old May 4, 2007 | 03:27 PM
blakh's Avatar
Default motor trouble NEED help FAST
my b16 was running... anyway i was on the highway went over a rough bump and the car died, battery light and oil light come on. pull over right away check the oil and was alittle low, added some. nothing looked wrong.. when i try to start its like it isnt catching and rolling over. the bat light and oil light are staying on, the bat. is fine (lights run fine, sub and speakers running no problems) help me figure out whats wrong! pleeeaase.
no cel, motor only has about 30k on it. please i need help fast.
Old May 4, 2007 | 05:35 PM
egb16pg's Avatar
Default Re: motor trouble NEED help FAST (blakh)
check the main relay/fuses. was the battery properly tied down?? the bump could have caused the battery to hop and touch the hood
Old May 4, 2007 | 05:54 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: motor trouble NEED help FAST (egb16pg)
did you check the signal wire on the starter? they are known for coming off
Old May 4, 2007 | 06:25 PM
hatchi's Avatar
check all fuses, wiring at the battery, alternator.
Old May 5, 2007 | 07:48 AM
blakh's Avatar
thanks for the help.
ill try after work...stuck there until 5.
Old May 5, 2007 | 09:39 AM
MJ0LNIR's Avatar
Default Re: (blakh)
Check that you didn't shake loose a ground too. Let us know.
Old May 5, 2007 | 10:31 AM
PinoyxEJ6's Avatar
Default Re: (dr92cx)
BECAREFUL THAT U DIDNT CRACK YOUR OIL PAIN AND SIEZED THE MOTOR!! lol..
Old May 5, 2007 | 10:41 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Yikez itz Jayr)
I agree, sounds like you knocked loose a battery terminal or a ground.
Old May 5, 2007 | 11:27 AM
blakh's Avatar
lol chill out guys! thanks for the help. i dont like being stuck at work i wanna get my car running. :*( iii waannntttt myyy carrrrr /cry
ok ok its not that bad but you get the idea.
Old May 5, 2007 | 12:00 PM
blakh's Avatar
jw though, why would my oil light stay on. i did check the oil and its fine. is there any reason for this??
Old May 5, 2007 | 12:21 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: (blakh)
the car is not running therefore no oil pressure, that is why the light came on. get it fired up and it will go out.
Old May 5, 2007 | 01:39 PM
blakh's Avatar
o ok, thanks.
rayzian
13
Feb 22, 2018 04:54 PM
si90rex
14
Apr 29, 2009 06:12 PM
solidsnakex37
Apr 19, 2008 11:45 AM
prendi
Jan 10, 2006 04:15 PM
hb_racer
Jun 16, 2004 08:05 AM
