Headlights won't shut off
Like the title says, my low beams are on aslong as the battery is connected...I'm really fed up with it. It's not the DRL, I removed the DRL relay and it stayed on. I then removed the headlight fuses and they shut off.
How do I troubleshoot this problem? It's either I can fix it, or I'm parting out. I'm too fed up with my car to even bother anymore.
could it just be the piece in the lever "when you turn on the lights" broke off and it connects it to 12V constant...sorry i dont know about headlights at all but bump for you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY »</TD></TR><TR><TD CLASS="quote">could it just be the piece in the lever "when you turn on the lights" broke off and it connects it to 12V constant...sorry i dont know about headlights at all but bump for you
Nah. Stuff was working good 3 weeks ago when I parked it. Now this...car is nothing but a wiring nightmare. Has gone thru so many changes. If I could pick up a beater for cheap I'd replace it in a heart beat.
I'd do anything to get rid of it.
</TD></TR></TABLE>Nah. Stuff was working good 3 weeks ago when I parked it. Now this...car is nothing but a wiring nightmare. Has gone thru so many changes. If I could pick up a beater for cheap I'd replace it in a heart beat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">
I'd do anything to get rid of it.</TD></TR></TABLE> 12V constant, switch, relay, and fuse
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY »</TD></TR><TR><TD CLASS="quote"> 12V constant, switch, relay, and fuse
I meant the car. But, my brother took my multimeter and left it somewhere, so that was 25$ well spent...
I've been wanting to fix it all day but I refuse to go buy a new one. And that info has little help value as I don't know how to check them. I do know fuses are good.
</TD></TR></TABLE>I meant the car. But, my brother took my multimeter and left it somewhere, so that was 25$ well spent...
speedycivicgurl
Aug 13, 2004 07:21 PM
