Dome pistons and Lots of boost....
Old May 30, 2002 | 01:00 PM
*Boostwerks*'s Avatar
Default Dome pistons and Lots of boost....
Is anyone using High CR dome piston's with around 18psi?
I'm looking for a 10:1 CR + 18psi + race gas + Phased water injection
anyone?
Old May 30, 2002 | 01:13 PM
b18bturbo's Avatar
Default Re: Dome pistons and Lots of boost.... (Bryson)
10:1 flatop is what i used with great sucess the dome pistons will be really tite clearances.
The 10:1 and good amount of boost and your car will fly ..... thats given..
Old May 30, 2002 | 01:18 PM
Default Re: Dome pistons and Lots of boost.... (b18bturbo)
Where can I find a flat top 10:1 with a 75mm bore?
Just wondering if you knew. How much are custom made Piston's(usually)?
Say... made by JE?
Thanks for any insight
Old May 30, 2002 | 01:28 PM
vtecvoodoo's Avatar
Future Texas Boy
I have some flat tops in 83mm
Old May 30, 2002 | 01:33 PM
b18bturbo's Avatar
Default Re: Dome pistons and Lots of boost.... (vtecvoodoo)
you can get some custom units made for around 580 or so.
Old May 30, 2002 | 02:52 PM
Sonny's Avatar
http://www.raceeng.com sells some flat top JE's that are 9:1 in any D series engine with a ZC/D16A1 Integra head. If you had some chamber work done to your head to reduce the chamber volume (ie, material welded in to give you additional quench), you could get 10:1 compression using those pistons. You can also mill the head a bit to up your compression, but I don't think you'll be able to remove enough material to get 1 full point increase.
Sonny
Old May 30, 2002 | 10:24 PM
Really? looks like I'm going that route then!
Thanks a lot!
Old May 30, 2002 | 11:44 PM
Sonny's Avatar
Give the guys at JE a call and ask them about their custom pistons. I believe they are around 600, but they may want you to order at least 2 sets. That's what Wiseco told me.
Sonny
TravisBiggie
Jan 11, 2014 04:26 PM
Spawne32
Sep 3, 2011 03:38 PM
traumatrix89
Feb 24, 2011 09:02 PM
honcrx91si
Jul 3, 2005 08:37 AM
Rydaddy
Nov 16, 2002 02:13 PM
