92-95 civic coupe skirt FIT HATCH
Old May 4, 2007 | 10:52 AM
rewerbcrx's Avatar
Default 92-95 civic coupe skirt FIT HATCH
will a 92-95 sedan (by coupe i meant sedan) skirts fit a 92 hatch ?
i have searched and its a pain in the butt to read through all the BS
looking for a knowledgable people to say YES or NO and if no why not... thanks
Old May 4, 2007 | 11:56 AM
aeboync's Avatar
Default Re: 92-95 civic coupe skirt FIT HATCH (rewerbcrx)
No..Think about it...which is longer? The hatch or sedan?
Old May 4, 2007 | 12:48 PM
HandicapRacer's Avatar
Default Re: 92-95 civic coupe skirt FIT HATCH (aeboync)
ACTUALLY i believe it does, do the EK skirt though, looks better. the worst youll have to do is cut new mounting holes on the rocker panel, and cut off the front of the skirt, then place your mudflap over the front end of the skirt and voila, it fits.
Old May 4, 2007 | 01:14 PM
Mashimaro's Avatar
it won't fit without modification.
Old May 4, 2007 | 05:29 PM
Like Butter's Avatar
handicap is wrong since the ek wasn't made during those years
Old May 4, 2007 | 06:29 PM
NOFX's Avatar
H-T White Ops
Default Re: 92-95 civic coupe skirt FIT HATCH (Like Butter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Like Butter &raquo;</TD></TR><TR><TD CLASS="quote">handicap is wrong since the ek wasn't made during those years</TD></TR></TABLE>
I think Mashimar is saying it will fit with modification while HandicapRacer is saying it will fit without modification. But HandicapRacer thinks he should do the '96-'00 (EK) sideskirts instead. HandicapRacer isn't saying there was an EK for those years.
Btw, your EK4 listed in your sig is likely an EJ6. USDM Civics were never EKs.
Old May 5, 2007 | 08:29 AM
rewerbcrx's Avatar
Default Re: 92-95 civic coupe skirt FIT HATCH (NOFX)
so what is it? VOID EK!!!! no ek
will the sedan fit the hatch? will a coupe fit a hatch?
Old May 5, 2007 | 08:46 AM
94c1v1cex's Avatar
like your sig dude...
It goes: bolt, washer, lip, washer, nut, nut, washer, bumper, washer, nut
Old May 5, 2007 | 11:44 AM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">so what is it? VOID EK!!!! no ek
will the sedan fit the hatch? will a coupe fit a hatch?</TD></TR></TABLE>
Is it a '96-'00 CX or DX hatchback? If so, it's an EJ6.
Check the chassis code link in my sig if you need to know any others.
Old May 5, 2007 | 03:34 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">i don't need to know what i have.... I KNOW WHAT I FREAKING HAVE!!!!! wow
what is wrong with the 92-2000 forum... very unknowledgeable comparibly to others</TD></TR></TABLE>
Chill out.
You said, "so what is it? VOID EK!!!! no ek." I thought you wanted to know what he had since you asked that. I said what it was. I didn't say what you have.
And why the hell would I know if 5G sedan sideskirts fit a 5G hatch... I don't and never have owned a 5th gen.
I can tell you they're different part numbers. I'm sure someone out there knows, and with enough searching you probably could too.
Looking at JDMshit, which sells aftermarket sideskirts, the sideskirts are made to fit either the hatch or the coupe/sedan. So that leads me to believe that the coupe and sedan sideskirts are interchangeable.
http://www.jdmshit.com/specials/
Modified by NOFX at 4:49 PM 5/5/2007
Old May 6, 2007 | 01:41 AM
Mashimaro's Avatar
you shouldn't assume that we're all idiots here dood. we are trying to help you out a bit.
i'll tell you this;
i just bought a '93 hatch back. i had brand new Wingswest RS sideskirts for my '93 coupe. they're too long and won't fit without modification (ie: cutting it shorter).
on top of that, i've sold them to a guy with a '93 4-door and they don't fit his car either because of the way the sideskirt sits (there's a small cut out for the coupe door). the coupe and 4-door are the same length however.
Old May 6, 2007 | 06:35 PM
Eran's Avatar
HT White Ops
You're kind of a bitch.
Old May 6, 2007 | 06:36 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">you shouldn't assume that we're all idiots here DUDE . we are trying to help you out a bit.
FURTHER more this is the most help so far....
holy crap no one know anything... very very unknowledgeable about your cars... this is why i stick to my EF's at least the people there can answer something i do not know...
DELETE THREAD ITS WORTHLESS B/S is no help to anyone looking for an answer about this same topic... </TD></TR></TABLE>
You'll catch more flies with honey than vinegar.
The thread has some helpful information. It won't be deleted just because you don't think it's helpful.
Perhaps someone will even find the thread and say, "Hey, I know that because I tried a few years ago."
And "dude" and "man" are often used for everyone here. It's just that most people here are guys. No one checks all the profiles. Don't take it personally. There are lots of girls here, but there are just much more boys.
And wtf, ma'am, your profile says your name is Jason anyway.
Old May 6, 2007 | 07:39 PM
Team RS2's Avatar
the answer to your question is yes with a grind wheel,
Old May 6, 2007 | 07:42 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: 92-95 civic coupe skirt FIT HATCH (Team RS2)
What a tool.
Go back to your Ef's with you insolence and ungratefulness.
Old May 6, 2007 | 07:47 PM
Team RS2's Avatar
Default Re: 92-95 civic coupe skirt FIT HATCH (ek forever guy)
there are alot of posts on this website that you have to ignore 80% ignore
10 % good
other 10% a littel of both with false informantion
Old May 6, 2007 | 07:52 PM
rewerbcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">What a tool.
Go back to your Ef's with you insolence and ungratefulness.</TD></TR></TABLE>
hahaha "what a tool" would imply that i don't have my own thoughts or can't make you sound like a jackA$$.... your worthless and totally nothing to the question being asked... your statement means absolutely nothing to help this site or any future builder ... congrats your a TOOL... you **** for brains
Old May 6, 2007 | 09:55 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">HE SPELLED IT WRONG YOU tart.... it has nothing to do with gender... what are you reading? holy crap
USEFUL INFO HERE GOES:</TD></TR></TABLE>
It's slang, you retard.
And you were the one who mentioned gender.
Since we're picking on people for spelling mistakes, you need to learn to spell:
knowledgeable
furthermore
it's
Also, your first post in the thread proves you might want to work on your grammar too.
Modified by NOFX at 12:18 AM 5/7/2007
Old May 6, 2007 | 11:03 PM
Kidnkorner's Avatar
hahaha "what a tool" would imply that i don't have my own thoughts or can't make you sound like a jackA$$.... <U>your</U> worthless and totally nothing to the question being asked... your statement means absolutely nothing to help this site or any future builder ... congrats <U>your</U> a TOOL... you **** for brains</TD></TR></TABLE>
while you are correcting others, how about making sure you are correct yourself.
It's you're not your.
Old May 9, 2007 | 02:54 PM
rewerbcrx's Avatar
who cares about spelling.. the point was that YOU AND everyone else that keeps posting are not helping one bit... AND READ ALL THE POSTS I NEVER BROUGHT UP GENDER, until someone said somethign about me being a girl....READ!!!!!
this proves the pointlessness of this entire thread... that once again you are commenting on nothign about the subject! THANKS.
PEOPLE POSTING THAT HAVE NOTHIGN TO DO WITH TOPIC
nofx
Lynx Bus Type R
Eran
ek forever guy
this thread is now pointless to any other people wondering thanks to everyone... you all push the H-T name with pride... thanks for helping no one
Old May 9, 2007 | 03:01 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">who cares about spelling.. the point was that YOU AND everyone else that keeps posting are not helping one bit... AND READ ALL THE POSTS I NEVER BROUGHT UP GENDER, until someone said somethign about me being a girl....READ!!!!!
nofx
Lynx Bus Type R
Eran
ek forever guy
this thread is now pointless to any other people wondering thanks to everyone... you all push the H-T name with pride... thanks for helping no one</TD></TR></TABLE>
I was one of the few that helped. You even said that earlier.
I only picked on your spelling after you first picked on someone else's spelling and brought up gender. And who called you a girl? I saw someone called you a bitch, but that has little to do with gender.
I commented about the subject. I don't know why you're commenting off of the subject. It's apparent there is probbaly not going to be anymore help from this thread.
"Will 5G sedan skirts fit on a hatch"
"It looks like yes, they will."
The End.
If they don't fit, sell them. I'm sure someone could use them.
robbys89
Jun 29, 2009 05:00 PM
atefcrx
17
Nov 27, 2007 04:02 PM
lsvtechatchy96
Jun 16, 2007 05:18 PM
Cashieboi
May 24, 2007 12:13 AM
jweezy225
Mar 18, 2004 08:01 PM
