Piston to head clearence?
Old May 4, 2007 | 09:40 AM
psegs80's Avatar
Default Piston to head clearence?
O.K. so I removed my cylinder head off my 98 JDM ITR motor and mesured the pistons to be 0.005" in the hole! An OEM head gasket is between 0.026-0.030" depending where you get your source from.
The big mystery for me is how much clearence do you actually need. Engine buliders like Larry at ENDYN recomends 0.044" piston to head clearence with factory rods and companies like mugen and spoon make head gaskets under 0.020" for the B18c motor?
I'm getting the quench pads welded in the combustion chamber and I want to run this motor as reliably tight as possible?
Thanks
Old May 5, 2007 | 12:33 PM
psegs80's Avatar
Default Re: Piston to head clearence? (psegs80)
Bump
OEM clearence 0.031"-0.035"
ENDYN recommends 0.044"
Spoon clearence 0.024"
Pat
Old May 6, 2007 | 10:10 AM
psegs80's Avatar
Who has 20 hours of race time with a mugen or spoon head gasket?
Thanks
Old May 6, 2007 | 01:31 PM
ENDYN's Avatar
The Old One
You might get by with .035" with a near-stock bore engine running factory pistons. I'd opt for a .030" Cometic gasket and you should be fine....
Larger-bore combinations running in excess of 10K need a bit more clearance.
Old May 7, 2007 | 05:14 AM
psegs80's Avatar
Default Re: Piston to head clearence? (ENDYN)
Thanks, I was aiming towards just that combo, i will try it and let you know how it goes!
I got some good numbers with stock clearences and no head work, and I'm hoping running it thighter will help!
Pat
yakuza
14
Oct 8, 2007 08:47 PM
SuicideSlide
Aug 10, 2004 01:43 PM
_BEN_
Jul 17, 2003 12:56 PM
Edwin
Jul 11, 2002 11:11 PM
comptechgsr
Apr 24, 2002 11:47 AM
