passenger window & driver door lock issues...HELP trying to fix to sell
i have a 2001 honda civic coupe and the power door lock on the driver side will not work. I am looking for find out how to fix it and what needs to be replaced. It works when i put the lock down manually. Now in regards to the passenger window, you can roll it down using the passenger side window control but not back up. what might be wrong and how can I fix it?
if you have any links or forums that will show or tell how to fix this please let me know
Have you Replaced the front speakers Recently?? i had the same issue turns out that the door pannel wasnt put in correctly. try removing it and putting it back on before you go through expensive procesdures.
all you really need is a philips screw driver and a flat head to remove some of the hidden parts of the door pannel. make sure not to mess with the Door's Trigger its a bitch to put back on ^_^
RATEDR
May 23, 2002 06:39 AM
