Rear Caliper Comparison Question
Old May 4, 2007 | 07:37 AM
NXSpoon's Avatar
Default Rear Caliper Comparison Question
I have been unable to locate any ITR rear calipers; are there any other calipers (or carrier brackets) that will locate the brake far enough out from the spindle to clear an ITR sized rotor? Possibly 97+ Prelude ? I am talking about REAR rotors, and calipers. I have the front setup already determined. The car is a 99 Civic Si.
Thanks, Ken
Old May 4, 2007 | 07:43 AM
citrus3000psi's Avatar
Default Re: Rear Caliper Comparison Question (NXSpoon)
I think rear nsx calps fit? Might need to confirm this
Old May 4, 2007 | 09:24 AM
NXSpoon's Avatar
Default Re: Rear Caliper Comparison Question (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">I think rear nsx calps fit? Might need to confirm this</TD></TR></TABLE>
Thanks !! Can anyone confirm that NSX rear calipers will bolt onto a rear ITR suspension and provide the necessary rotor clearance?
Frankly, I do not have the payroll or time to "try" something that "might" fit. Right now, I am at a stall with this conversion. My only other choice is to use my stock calipers and get Si sized rotors redrilled to 5X114.3. And I really don't want to do that.
Old May 4, 2007 | 10:34 AM
slofu's Avatar
pretty sure ep3 rear calipers fit (i think they're what i installed on my car last year)- but to retain e-brake function you have to swap L-R, so you have to either disconnect and invert them to bleed, or drill and tap to relocate bleeder screw.
Old May 7, 2007 | 09:36 PM
BrakeExpert's Avatar
I can confirm that an NSX caliper brackets will require NSX rear calipers, which use a larger pad and require a ventilated rotor.
The EP3, RSX, TSX, ITR and CTR rear caliper brackets will all work for your application to clear the 10.2" rotor.
The back calipers you want are from a CTR or ITR. The EP3 and RSX ones require swapping left to right, and changing the hammer and L bracket (PM me if you needs these bits.) It ends up looking the same as ITR/CTR rear calipers.
Like so.
No info on the TSX rear caliper. No confirmation on prelude calipers, most calipers that bolt to this setup have the e-brake attachment at the totally wrong angle to where it just wont fit on the car. IF you don't care to have an e-brake then you have tons of cars to source.
Side note: if you need your rotors redrilled, I can do that for you.
Modified by BrakeExpert at 1:46 AM 5/8/2007
Old May 7, 2007 | 11:35 PM
SOHC_me's Avatar
Default Re: Rear Caliper Comparison Question (BrakeExpert)
all 97 + prelude calipers are the same as ctr, itr and accord v6, and maybe accord wagons BTW i have some 97 prelude rear calipers and 2 rebuild kits and some hawk hps pads for sale. pm me if your interested.
Old May 8, 2007 | 08:36 AM
Default Re: Rear Caliper Comparison Question (SOHC_me)
No they aren't please double check your sources. The Accord e-brake attaches at a different direction.
Old May 8, 2007 | 08:43 AM
NXSpoon's Avatar
Thanks all. I stumbled upon an article showing an EP3 rear brake conversion. I found a member selling his, so I should have them soon. I almost went with a new set from the dealer for $117 each, except they wanted to charge a core charge of $60 per? Are there so few of them that they need to charge for the core?
Anyways, my little "project" should be done by this weekend.
JohnnieChimpo
Suspension & Brakes
Dec 8, 2008 07:45 PM
-Championship-
Jul 7, 2006 10:48 AM
mrlegoman
Jun 22, 2006 10:52 AM
MiraiZ
Sep 27, 2003 07:12 PM
QWKPHKR
Feb 21, 2003 09:47 PM
