Some hints/help at the engine rebuild
Old May 4, 2007 | 02:58 AM
cioli's Avatar
Default Some hints/help at the engine rebuild
i have an eg6 b16a2 hatch and i want to put some new piston ring set,seat valve adjustment and all that's necessary when i will open it.
i was thinking to polish ( with a small diameter sandpaper ) the intake mainfold,the head,the sewer valves ( sorry maybe it's not the best word,but i am not english ),the head of the piston and maybe the rod. is that a bad idea ?
any tips or tricks at the engine rebuild in order to pull stronger ?
Old May 4, 2007 | 09:10 AM
cioli's Avatar
bump for some hints
Old May 4, 2007 | 09:21 AM
instructor74's Avatar
Default Re: (cioli)
You really shouldn't take sand paper to the piston, the connecting rods or the valves. You can gasket match/ port the intake and the headfor better flow.
Old May 5, 2007 | 04:26 AM
cioli's Avatar
it's possible to wreck the piston head if i'll use some small diameter sand paper ? a fine one ?
failureisfirst
Feb 1, 2010 08:54 PM
07civicEF
Jul 31, 2006 02:57 PM
92hatchling
Mar 5, 2006 02:53 PM
USDM 4G VTEC
17
Jan 20, 2004 11:11 AM
assasin
Jul 6, 2003 06:07 PM
