CD mounts interchangeable w/ 92-96 Prelude mounts?
Old May 3, 2007 | 09:11 PM
rhdune16's Avatar
Default CD mounts interchangeable w/ 92-96 Prelude mounts?
Just as the title says. All my mounts are SHOT. There is no place that makes aftermarket mounts for the CD accords. I know the driver side mount can be done w/ a little bit of grinding but what about the other mounts. I have searched on many sites and haven't found a clear answer. From what I have read it sounds like you can use the prelude transmission mount and the rear mount only if you use the rear bracket from the prelude.
I ask this because Innovative made Prelude mounts, and ESP made the mounts for the prelude as well.
If the prelude doesn't work will the CB mounts fit because ESP made CB mounts as well...
We CD guys always get shafted w/ the last ones left....
Old May 3, 2007 | 09:15 PM
lowered94accord's Avatar
Default Re: CD mounts interchangeable w/ 92-96 Prelude mounts? (rhdune16)
why dont you try the mounts they are making for the CD accords..in the FAQ surely they will be done soon?..who knows...if not im not sure about the lude mounts
Old May 3, 2007 | 10:55 PM
rhdune16's Avatar
Also I have the F22... so that's why the question is still unanswered. I searched like crazy and all I could find was about the H-swaps...
Old May 4, 2007 | 08:04 AM
ESP-net
Guest
Posts: n/a
Default Re: (rhdune16)
just wait lil grass hooper...I'll have them out soon enough
Old May 4, 2007 | 08:21 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (ESP-net)
When do you feel that'll be? He NEEDS solids mounts. Never seen anyones motor rock so much.
rhdune16,
how is the motor? did you get time to work on it and locate the problem?
I've heard the same about the prelude mounts. You can use them but you need to use the rear motor mount bracket for the rear prelude motor mount to work.
Old May 4, 2007 | 09:05 AM
ESP-net
Guest
Posts: n/a
Default Re: (TouringAccord)
rhdune...is your car a auto to 5 spd or 5 spd from factory?
Like I mentioned send me the rear and driver side mounts and I will make the kit
Then I will have the CD F series 5 spd out of the way...
The mount combo goes like this:
CD 5 spd H and F series-
92-96 Prelude H and 94-97 F series 5 spd transmission mounts are identical
92-96 Prelude H rear mount will work with H swap
The driver side and rear mount for the CD F series I will need to pick up from someone in order to make it...
The driver side CD H mount I will be making the week after next with a customers car...
Old May 4, 2007 | 09:42 AM
H-T Order of Merit
ESP,
I sent you an IM about the mounts you need to finish the mount kit
theycallmeCUZ!
May 19, 2009 07:25 PM
siregcivic
May 20, 2008 08:24 PM
maverik
Jan 8, 2007 08:50 AM
SimbaDogg
11
May 25, 2003 01:00 PM
juicedh22
Dec 4, 2002 08:31 PM
