help please!!
Old May 3, 2007 | 07:27 PM
lCHaCHeel's Avatar
Default help please!!
well i swapped in a ls/v swap in my 92 cx hatch and im using a obd-1 gsr harness well everything plugs up to the harness but it seems to be missing the o2 sensor plug unles its not suppose to have one well i got a 4 wire o2 sensor (1-white, 1-green, 2- solid black, wires) and was wondering if anyone knows how to maybe wire it direct to the ecu or maybe splice it into wires from the shock tower clips thats the only code im throwing and i want to fix it tired of the check engine light being on all the time i tried searching found a couple of obd-1 p72 ecu pinouts but dont know which wire goes where please someone help me
Old May 4, 2007 | 07:20 AM
lCHaCHeel's Avatar
Default Re: help please!! (lCHaCHeel)
help me please help me please
Old May 4, 2007 | 08:52 AM
lCHaCHeel's Avatar
Old May 4, 2007 | 06:53 PM
hatchi's Avatar
Run O2 Sensor signal (white) To D14
Run O2 Sensor signal Ground (green) to D22 (or any good Ground)
Run O2 Sensor Heater Circuit Control (black) to A6
Run the other black heater circuit power wire to (A25) or any good switched +12VDC source.
HondaFerris
Aug 5, 2014 09:05 AM
BlackCivicEX
29
Jan 21, 2011 07:19 AM
Ls1 FD3s
Aug 27, 2007 06:44 PM
Hondamonster
12
Jun 21, 2007 08:19 PM
civicflow
10
Jan 23, 2007 09:56 PM
