B18b Swap into 88 CRX auto HELP HELP HELP@!@!@!@
Old May 3, 2007 | 06:58 PM
nikkarocky's Avatar
Default B18b Swap into 88 CRX auto HELP HELP HELP@!@!@!@
I have an 88 crx dx dpfi automatic and i have 2 ls motors a b18a and b18b and i want to keep it automatic. i have a couple questions:
1. Which motor is easier to swap into my crx.
2. What wiring or re-wiring do i have to do.
3. Does any one have a step by step how to guide for this exact swap setup.
4. What are all the parts that i need to make this swap possible. ( i know what parts are need...just making sure i didnt miss anything)
5. Is there anything else i need to know???
Any help with this would be awesome. Thanks alot guys.
Old May 3, 2007 | 07:48 PM
SnIpErS-GsR's Avatar
Default Re: B18b Swap into 88 CRX auto HELP HELP HELP@!@!@!@ (nikkarocky)
Both of those motors are the same, I think the only diff is the intake manifold. Which is almost the same. I ended up having to get way more for my swap than what other people were saying. My list just for the swap went:
d-series to b-series motor mounts
ls and dpfi engine harness to rywire
b-series shift linkage
ls axles
ls intermediate shaft
rear engine mount bracket
ls throttle cable
ls clutch cable
then a tranny that came off a b-series motor, I used a 93 gsr cable tranny.
Most people use b16 trannies cause they are more common.
Then I ended up rebuilding the whole upper end. Got the head work done and new gaskets, head studs, eveything was new and/or replaced minus the block.
Hope this helps! GL!!!
Modified by SnIpErS-GsR at 9:06 PM 5/3/2007
Modified by SnIpErS-GsR at 9:18 PM 5/3/2007
Old May 3, 2007 | 10:49 PM
nikkarocky's Avatar
Default Re: B18b Swap into 88 CRX auto HELP HELP HELP@!@!@!@ (SnIpErS-GsR)
Yeah i knew they were the same motor but i thought that b18a was easier. Do i use the same ls axles even if its a automatic?? Thanks man
Old May 3, 2007 | 11:28 PM
HF2ZC's Avatar
you're going to need an automatic transmission that bolts up to your B-series engine. The stock one won't work. Also you need an automatic ECU. As far as wiring changes, there should be a thread in the FAQ.
Old May 4, 2007 | 05:34 PM
I dont think the axles are the same. Like HF2ZC said, you will also need an auto or manual ecu depending on what tranny you use. When I first did mine I swapped everything the exact same as a LS would be. 92-93 integra use pr4 OBD1 ecu's. If you use a FMU like hondata you can use any ecu you want. Now I run a p28 with s300. Just make sure vtec is not enabled.
91hondarex
Jun 12, 2008 04:11 AM
Project_ED8
Oct 21, 2003 02:14 AM
Teckademic
Sep 22, 2003 05:52 PM
