limter 3k?!!? sometimes!! yea weird!!
Old May 3, 2007 | 04:42 PM
BennTec's Avatar
Default limter 3k?!!? sometimes!! yea weird!!
right got an issue with my d16z6 hope you lads can help me.
I have done a search, but with no real luck.
Basically sometimes moving from stand still the car wont rev past 3k in any gear. if i hold it there for a while as it splutters it then frees up and continues to go up there the rev range. I notice this alot when ive jst started the car from cold and drive off but it can happen and does happen when the cars warmed up to.
somtimes this happens and sometimes it doesnt.
Over 3k..the car drives fine.
i do sometimes get code 43(fuel supply)
parts ive changed:
Spark plugs
spark plug leads(put on my oem ones)
fuel filter
Rotor arm
Fuel regulator
air filter
Lambda sensor x2
map sensor
Check my grounds and cleaned them
Check and tighted my throttle cable
Modifications:
skimmed head ported polished
aem cai
Dc sports manifold
apexi center section
tanabe rear
Custom De-cat
Any other suggestions?. as this problem is getting on my ****.
Cheers
Benn
Old May 3, 2007 | 05:03 PM
97Ej6mike's Avatar
Limp mode?
Or some really bad misfiring.
Old May 3, 2007 | 06:31 PM
BennTec's Avatar
Default Re: (97Ej6mike)
well sounds like its misfireing when u hit the 3k limter.
..then if stamp on the throttle ..it goes away.
its very weird..
cheers
Benn
Stagerguy
Feb 5, 2022 02:57 PM
sean2000gt
May 22, 2014 06:35 AM
EDWINV00SI
10
Apr 2, 2011 10:32 AM
rx_86
Mar 4, 2009 02:04 PM
