3 questions i need help with
Old May 3, 2007 | 04:02 PM
NSfit's Avatar
Default 3 questions i need help with
1) the sensor on the back of the throttle body ( i think its called the TPS) what does it do and how do i know when its adjusted right?
2)what should the rpm of the idle be at?
3)i just finished my swap. (gsr bottom and b16 head) im running a p28 how long can i run the ecu the motor with out having it chipped?
thanks so much for your guys help through my entire swap!
Old May 3, 2007 | 04:07 PM
yee SERIOUS's Avatar
1. yes it is a tps. it tells the ecu how much throttle is open so the ecu can tell how much fuel to add for the amount of air being flowed in.
2. cars are to idle ~750
3. a life time if you wanted. it's just best to run a proper basemap.
Old May 3, 2007 | 04:28 PM
NSfit's Avatar
Default Re: (kidsafe yee)
thanks kidsafe yee
any more input guys!
Honda_San
Aug 27, 2009 08:40 AM
MelszEg6
Jan 11, 2009 08:12 AM
wpgcivic
May 14, 2004 01:20 PM
TuCKiNaLL4s
Sep 24, 2003 09:44 AM
SpoolnG2
Oct 17, 2002 06:51 PM
