Honda Accord Gasline Replacement
1997 Accord is leaking gas. Is this a big job to change out? Looks straight forward enough but there are 5 lines running in parallel from the back end to the engine. Any gotcha's?
thanks
Bryan
thanks
Bryan
Where's it leaking gas from? If it's leaking from one of the lines, than just replace the line. I'm not sure on how hard this will be as I've only replaced the gas tank on my truck and have never had to touch anything with the fuel lines or tank on my Accord.
Thanks Deface8. The lead is back near the gas tank but after inspecting it the line(s) look like they're in pretty bad shape. There are actually 5 lines running in parallel. I suspect some are break lines. They look bad too. They have white corrosion on them, probably as a result of road salt.
Thanks
Bryan
Thanks
Bryan
derekk24
Apr 11, 2017 08:34 AM
HankYee
Oct 16, 2001 06:12 PM
