.010 Over???
Dose anyone know where to get engine bearings main and rod, for a D16Z6 .010 oversize? i have looked all over and can not find any; Im only finding then in .020 and or .025 over? any help will be appreciated, thanks.
do you really need to change the rod and main bearing. the oil clearance should stay the same and you should be able to pick up some stock ones. and should work. try to google it. i tryed but cant find either
my crank was ground to .010 under so i know what im looking for i had .010 in before (says on back of old bearing) but put new pistons in and am putting new ones in but cant find anyone with that caries them now.
evosix
Engine Machining & Assembly
Sep 25, 2017 11:51 PM
RiipTiide67
Nov 11, 2011 09:08 PM
djvtoner
Sep 13, 2004 01:25 PM
