H22A SWAP PROBLEM
Old May 3, 2007 | 12:29 PM
93formula's Avatar
Default H22A SWAP PROBLEM
we just swapped a jdm h22a into a 95 accord that previously had a vtec engine. everything is in and fine, but when we plug in the jdm h22a ecu it doesnt run, fires up and dies right away, did the pin a11/a6 swap and still same problem. runs fine with the stock accord ecu though. any help? yes i did the search.
Old May 8, 2007 | 12:30 PM
rr1289's Avatar
Default Re: H22A SWAP PROBLEM (93formula)
ihave a h22 in my 96 accord how did you do yours what wire harness did you use and how did you make it work need help
Old May 8, 2007 | 07:11 PM
HondaccordH22aJdm's Avatar
Default Re: H22A SWAP PROBLEM (rr1289)
theres a few wires you need to splice and cross. and knock senser and everything else in? is the jdm ecu faulty? it could be a bad ecu. if u live in hawaii i would let u barrow mine to see if thats the problem but other then that not sure.
Old May 8, 2007 | 07:23 PM
rr1289's Avatar
Default Re: H22A SWAP PROBLEM (HondaccordH22aJdm)
did you use the the h22 harness or the accord stock harness the motor harness thats what im takeing about and im useing the accord stock ecu to and what is a knock senser and were is it and how do you splace it in and im from nj so i cant use your ecu wright back please
Old May 8, 2007 | 08:15 PM
Alpinestar03's Avatar
^ Its hard to tell what your trying to say since your not using whole sentences..
But its sounds like a bad ecu. Buy a USDM ECU and see how it goes. Are you running the internal coil distributer that yours came with?
-Eric
Old May 9, 2007 | 06:00 AM
rr1289's Avatar
Default Re: (Alpinestar03)
whats a usdm ecu? and yea im running a internal coil distributer. its the 1996 accord harness and ecu. sorry about not putting .S i never do im to lazy. lol
RACEPAK
Jan 28, 2011 03:31 AM
3litre190
Jul 24, 2007 02:49 PM
steve_meyer
May 22, 2004 05:32 PM
92talon4evr
Mar 3, 2003 05:55 AM
pwr5hift27
Dec 9, 2002 10:23 PM
