Belt squeak when shifting gears.
Old May 3, 2007 | 11:03 AM
Libertariat's Avatar
Ek Forever y0!
Default Belt squeak when shifting gears.
Okay, so when I'm at WOT and shift gears at the end of the gear, i usually hear a betl squeak. Sometimes it does it if i gradually take the y7 up to about 5500 rpms.
I'm pretty sure it's the A/c belt skipping or turning on when I get into that rpm range.
But my question is, Why is it only at high rotations?
I'm not 100% it's the A/c belt, it could be anything but that. This is the only time it squeaks.
What do you guys think?
Old May 3, 2007 | 11:06 AM
DaX's Avatar
DaX
Loved
Community Favorite
Is this only when your AC is running?
It could be the alternator belt if the alternator is loading up with a large electrical pull - are you boomin' out a stereo while you're at WOT and shifting gears?
Old May 3, 2007 | 11:08 AM
Ek Forever y0!
Default Re: (DaX)
I always have my A/c on and I'm always listening to the radio.
but I've turned the radio off before to listen for it, and it still happens.
Where are you in GA?
Old May 3, 2007 | 11:09 AM
a_wishbone's Avatar
Default Re: Belt squeak when shifting gears. (ek forever guy)
Belts too tight. Check all three belts
Old May 3, 2007 | 11:10 AM
Ek Forever y0!
Default Re: Belt squeak when shifting gears. (a_wishbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a_wishbone &raquo;</TD></TR><TR><TD CLASS="quote">Belts too tight. Check all three belts</TD></TR></TABLE>
So you think them being too tight will make them squeak at higher rpms?
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">I always have my A/c on and I'm always listening to the radio.
Where are you in GA?</TD></TR></TABLE>
Check the belt tensions. As the guy stated above, too tight could be the culprit, just as well as too loose.
Old May 3, 2007 | 12:01 PM
19cIvIc94's Avatar
Default Re: (DaX)
My car use to do that when i had ac on and got past 5000 rpm, the problem was that the belt was loose.
Old May 3, 2007 | 12:48 PM
Ek Forever y0!
Default Re: (98_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98_Civic &raquo;</TD></TR><TR><TD CLASS="quote">My car use to do that when i had ac on and got past 5000 rpm, the problem was that the belt was loose.</TD></TR></TABLE>
I'll check it out
That's what I figured it was, I'd just rather consult the populous than get my hands dirty.
Besides it's 94 outside, And i'm in GA.
EGed up from the seat up
May 25, 2010 03:45 PM
M.D. CIVIC
10
Feb 23, 2010 06:47 PM
iOn
Apr 29, 2008 09:03 AM
BB1 H22A LUDE
Jun 17, 2007 04:36 PM
blueaccord94
May 19, 2005 06:16 AM
