Carsound Cat 94006 reliability?
Old May 30, 2002 | 11:06 AM
Tommy_Gunns's Avatar
Default Carsound Cat 94006 reliability?
How is the reliability of the carsound 94006 catalytic converter? Just had mine installed and was wondering how long this puppy will last from daily driving in freezing temperatures in the winter and super hot summers.
Old May 30, 2002 | 11:35 AM
guyuenvy's Avatar
Default Re: Carsound Cat 94006 reliability? (Tommy_Gunns)
ive seen car sounds mess up in a few months makes me wonder if its something good to have
Old May 30, 2002 | 12:00 PM
onyx00's Avatar
Default Re: Carsound Cat 94006 reliability? (guyuenvy)
In Arizona with pretty constantly nice weather I had one go out after 4-5 months and another that went out in one month. I have had my current one for 2 weeks and no problems yet.
In talking to another board member about this problem (I will let him chime in if he wants; I won't try to speak for him) Carsound suggested that their 95000 (I think, again, other board member can correct me if needed) was much heavier duty and might work better, but the cost was about $50 more.
My suggestion is that if you buy it from a shop, ask before hand what their repair/replacement policy is.
Mark @ LandSpeedRacing has been extremely helpful to me and replaced my cat. along with re-doing all welding, etc for free where normally you get a new cat. core for free, but must pay to have it re-welded, etc.
Make sure your care is properly tunned as well. If you are running too rich or lean, that could cause problems. On boh of my failed cats. the core was actually perfect, no signs of any kind of rich or lean situation occuring.
As for my opinion of Carsound themslves; they suck. No real customer service. It all comes down to the shop you buy it from and how well they handle it for you.
Old May 30, 2002 | 05:36 PM
Default Re: Carsound Cat 94006 reliability? (onyx00)
How did they fail? Plugged?
Old May 30, 2002 | 05:46 PM
98itR484's Avatar
I've had mine that i got from IPS on my car for about 6 months, and no problems as of yet.
Old May 30, 2002 | 06:03 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: Carsound Cat 94006 reliability? (98itR484)
I got mine form IPS and I've had ot for over a year. No problems
Old May 30, 2002 | 06:05 PM
disordeR's Avatar
did you install the carsound with a header or exhaust? notice any difference?
i hope mine doesn't fail on me.. whenever i do install it..
Old May 30, 2002 | 06:35 PM
1GreyTeg's Avatar
The last generation of Carsounds had a defect that loosened the catylist and it just rattled around. The current generation doesn't have that problem.
I've had my 94006 for a year this July, Got it from Mike at IPS racing. It works fine. Passed inspection, sounds a bit more agressive but, all around it has no problems that I have encountered. Good stuff if you are upgrading your exhaust system. Carsound gets my !
Get in touch with Mike at the link in my Sig for IPS.
good luck,
A.
Old May 30, 2002 | 08:07 PM
Isaac's Avatar
New User
I hate mine! I had it on my car for about 4 months and now it's a rattling mess. I ordered mine from R&D and unfortuantely Dave advised me that I need to go through Carsound directly which is a bitch. Basically, I have to buy a new cat, get that re-welded etc, and then send Carsound my defective cat. Even that isn't a guarantee. As said before, check with the warranty offered through the shop you purchase it from. Wasting $250 or so in a few months sucks!
Old May 30, 2002 | 08:15 PM
onyx00's Avatar
Nop,e abosilutely nothing wrong upon visual inspection. I am just saying that if they fail because of the car not being tunned Carsound will probably tell you to go screw yourself.
Old May 30, 2002 | 08:16 PM
Default Re: Carsound Cat 94006 reliability? (Waxing "The Carrot")
Are you sure the noise is coming from the inside of the cat and not the outside? It could be just the heat shield rattling. Try adding a **** load of spot welds around the perimeter of the heat shield and see what happens.
Old May 31, 2002 | 02:19 PM
-TJ's Avatar
-TJ
I've had a 3" carsound cat on my SC civic for a year now - the only thing that's happened is the heat shield started to rattle after about 1 month. I edge welded it - fawk spot welds. All is well otherwise...knock on wood...
SlimBB4
Mar 12, 2006 01:17 AM
Maengelito
Apr 10, 2002 06:41 PM
93delsol
Apr 4, 2002 01:03 PM
onyx00
Apr 3, 2002 03:57 PM
Halo
Jul 14, 2001 08:50 AM
