valve adjustment, feeler guages, is this one ok?
Old May 3, 2007 | 10:58 AM
nexgen91's Avatar
Default valve adjustment, feeler guages, is this one ok?
I bought a new set of feeler gauges to adjust the valves on my b16 and DOHC 1.6i-16s (ZCs) It has .15mm and .20mm and nothing in between, now the repair manual specs say .15 -.19mm for intake and .17 to .21mm for exhaust. So my question is, would this be ok to use and if so would it be .15mm for intake (since that is the spec, even though it seams kinda low to me) and .20mm for exhaust? Or should I get another new set of feeler gauges? Thanks
Old May 3, 2007 | 11:04 AM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: valve adjustment, feeler guages, is this one ok? (nexgen91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nexgen91 &raquo;</TD></TR><TR><TD CLASS="quote">I bought a new set of feeler gauges to adjust the valves on my b16 and DOHC 1.6i-16s (ZCs) It has .15mm and .20mm and nothing in between, now the repair manual specs say .15 -.19mm for intake and .17 to .21mm for exhaust. So my question is, would this be ok to use and if so would it be .15mm for intake (since that is the spec, even though it seams kinda low to me) and .20mm for exhaust? Or should I get another new set of feeler gauges? Thanks</TD></TR></TABLE>It will work. Or you could get another set of feeler gauges. But simple answer yes it will work. I adjust to the lowest # so the .20mm would bother me.
Old May 3, 2007 | 11:09 AM
nexgen91's Avatar
Default Re: valve adjustment, feeler guages, is this one ok? (ILcrxsi1)
what set should I get? I cant find one that specifies the sizes.
Old May 3, 2007 | 11:11 AM
ILcrxsi1's Avatar
I got a craftsmen set from sears. Mine works but I go by inches and not metric.
Old May 3, 2007 | 11:15 AM
ILcrxsi1's Avatar
This should work, but it doesnt say what the individual sizes are.
http://www.sears.com/sr/javasr...e=Yes
They don't have the set that I have online anymore.
jerzey908
May 13, 2009 01:34 PM
civic919900
Sep 27, 2005 08:52 AM
Wookey
Jan 18, 2005 03:56 AM
Behan
Nov 17, 2003 05:34 PM
P1mpSlap
Apr 21, 2003 12:36 AM
