FS: Brakes - JDM Prelude BB6 front knuckles, 28T brackets, DA Calipers, and more!
JDM Prelude BB6 front spindles - SOLD
Acura NSX 28T brackets - SOLD$
Prelude VTEC rotors redrilled to 4x100 - NEW! - $110
This is a pair of unused 11.1" Prelude VTEC rotors redrilled to the 4x100 bolt pattern. If you have done the front Type-R brake upgrade on a civic/integra, this is the rotor you want. These were redrilled and are new, only mounted for a few seconds on a test knuckle to ensure they fit perfectly hub-centric, and they do.
Acura Integra GSR DA front calipers *painted black* - 85$
Calipers are in great shape and were sandblasted, painted with a very durable high temperature primer and painted with VHT high temp caliper paint, and rebuilt, so theres no paint on the rubber seals or banjo bolt or anything like that. Comes with brackets with slide bolts, pad spring, and retainer clips. Good upgrade for a Civic EX or Si.
1995 Integra GSR UCAs - $4.
1995 Integra GSR Compensator arms - $7.
These are the Rear Upper control arms, Rear compensator arms, to a 95 Integra GSR. Will fit all 94-01 Integras and 92-95 civics and Del Sols (since they have all the same suspension.) In great shape, the bushings are all good.
D16Y7 Intake manifold - $5
In like new condition, clean, no scratches on face, vacuum line attachment tubes are perfect. Although the pic is bare, it comes with the throttle cable attachment bracket, the intake manifold bracket to bolt to the block, and the hose bracket for the side.
Great seller! He will hook you up with a great brake setup... He is the only person i know that has NSX brakes on his EK!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert »</TD></TR><TR><TD CLASS="quote">your girlfriend called me last night Evan, tell her the check is in the mail and to work on her 'technique'. OH!</TD></TR></TABLE>
will do.
Shes always been a lil sloppy... at least she was better at it than your mom was
will do.
