Wheel bearings going out, rear
Old May 2, 2007 | 05:49 PM
Patman's Avatar
Default Wheel bearings going out, rear
anybody have any tips, tools, suggestions for the replacement, should I do both or just one? Dealer around here wants about 90 for the hub assembly, I think Im going with the oem on this one.
Old May 5, 2007 | 07:11 AM
Patman's Avatar
bump
Old May 5, 2007 | 05:59 PM
hondadude's Avatar
Default Re: Wheel bearings going out, rear (Patman)
I'd just change the side that is making the noise;
You are going to need a 32mm socket for the hub nut, and 10,12,14 wrenches Good phillips bit.
It's a gravy job !!
Remove the brake caliper and bracket, then the screws holding the rotor on, I favor an impact driver for those screws; pop off the center cap, and remove the 32mm nut.
There is a torque spec for the hub nut,[127 ftlbs I think??] but if you put it back to where it was by looking at the 'punch mark' you should be good to go.
Old May 5, 2007 | 07:40 PM
Patman's Avatar
awesome, sounds easy, do I need a bearing packer or grease or anything?
Old May 5, 2007 | 10:09 PM
lowered94accord's Avatar
Default Re: (Patman)
id get some grease if i were you...make it a little easier to get out the next time..also I myself would go ahead areplace both..if one side is going out you the other side probably isnt to far from going out..go buy an impact driver..just a regular screw driver isnt going to take those screws out..trust me!.. very simple job though good luck
Olaisen
Suspension & Brakes
Sep 3, 2010 07:20 PM
Mr.Speed
Jun 15, 2010 03:37 PM
dbailey
Sep 13, 2009 09:57 AM
yohan
Mar 16, 2005 09:35 AM
PAID-$$$
Jul 26, 2004 08:27 AM
