Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
What size memory card do you use in the PC Card slot of your Navi?
Old May 2, 2007 | 04:47 PM
LByellowStang's Avatar
Default What size memory card do you use in the PC Card slot of your Navi?
I was using a 2GB Compact Flash card, then I decided I wanted more space so I bought an 8GB. I didn't realize there was a 2GB limit. The manual says other capacities may work, anyone have any luck going above 2GB?
Old May 2, 2007 | 04:51 PM
WILD_WILL's Avatar
Default Re: What size memory card do you use in the PC Card slot of your Navi? (LByellowStang)
I run 2gb but i have to get the navi replaced because some how the pins inside the pc card slot were bent from the factory so i never got to use it but i bought a sandisk 2gb card.
Old May 2, 2007 | 06:12 PM
FBPSidan's Avatar
Default Re: What size memory card do you use in the PC Card slot of your Navi? (WILD_WILL)
im using a 4gb with no problems
Old May 3, 2007 | 01:58 AM
Default Re: What size memory card do you use in the PC Card slot of your Navi? (FBPSidan)
What type and brand of memory are you using?
Old May 3, 2007 | 04:29 AM
FBPSidan's Avatar
its a knock off sandisk SD card. i got it off of ebay. 30 bucks ftw!
slowpokesi
May 11, 2005 10:25 PM
ciRcuitJerk
Mar 14, 2003 12:53 PM
OKSolSi
May 21, 2002 05:32 PM
