Problems with B16 swap into 91 CRX DX
Old May 2, 2007 | 03:55 PM
CO_CReX's Avatar
Default Problems with B16 swap into 91 CRX DX
Ok guys, I had a 89's Si with a B16 swap, well that car got destroyed so I yanked the motor and picked up another CRX. The new CRX is a 91' DX that was converted to MPFI. Well I swapped in my B16 and for some reason my throttle cable doesn't reach for ****. I believe they swapped the throttle cable out to a Si one because I went to the junkyard and yanked an Si one myself and it is the exact same thing.
My question is, do I need to pick up a DX throttle cable since this is a DX body instead of an Si throttle cable??
This is driving me crazy so any help would be greatly appreciated!
Thanks!
Old May 2, 2007 | 05:17 PM
Suck my DX's Avatar
Default Re: Problems with B16 swap into 91 CRX DX (CO_CReX)
usually its not the throttle cable thats the problem its the throttle cable bracket....just modify yours to work...either cut and weld a new piece to it, or take a piece of metal and drill the holes in it to make it fit...
Old May 3, 2007 | 07:10 AM
mahatma's Avatar
Default Re: Problems with B16 swap into 91 CRX DX (Suck my DX)
90-93 integra is longer
Old May 3, 2007 | 10:00 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Problems with B16 swap into 91 CRX DX (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">90-93 integra is longer</TD></TR></TABLE>
I thought this is what you had to use for a B-swap anyways.
Old May 3, 2007 | 12:39 PM
mahatma's Avatar
Default Re: Problems with B16 swap into 91 CRX DX (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
I thought this is what you had to use for a B-swap anyways.</TD></TR></TABLE>
i think j00 are right. that's the one that worked for me.
i used the stock clutch cable though. i always get those confused when people ask about it.....
Old May 3, 2007 | 01:20 PM
Suck my DX's Avatar
you can still use the stock dx cable if you modify the bracket....but yeah the teg one is plug n play...well kinda, you still need to adjust it.
XplicitzOldSkoolDA
Aug 16, 2008 08:01 PM
crxpwr1
Jul 10, 2006 09:57 PM
SomeDude56
Apr 14, 2006 05:21 PM
nwrallyciv
Feb 20, 2005 12:22 PM
f@sth@tch89
Jun 25, 2003 05:23 AM
