mpfi ?
Old May 2, 2007 | 10:49 AM
damn_import_culture's Avatar
Default mpfi ?
i have my dpfi harness a injector resistor box and a si dizzy i cant find a full si harness at pick and pull so do i need to just cut dizzy plugs and injector resistor plugs off a sedan or si and splice em in?
can i do mpfi with a set of 92 95 injector set and rail? on tight budget
having a kid
Old May 2, 2007 | 11:21 AM
Default Re: mpfi ? (damn_import_culture)
any help
Old May 2, 2007 | 02:12 PM
janz3n's Avatar
wow... faq is your friend buddy.
Old May 2, 2007 | 02:13 PM
janz3n's Avatar
you can use the obd1 injectors, dont know about fuel rail. and then youd ont need the resistor box. look it up to find out how to wire obd1 injectors for your mpfi swap though.
Old May 7, 2007 | 02:21 PM
Default Re: mpfi ? (janz3n)
what did ont need resister box mean
Old May 7, 2007 | 03:11 PM
janz3n's Avatar
lol.... "you dont need the resistor box".
i type too fast sometimes.
Old May 7, 2007 | 05:06 PM
danb18c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damn_import_culture &raquo;</TD></TR><TR><TD CLASS="quote">i have my dpfi harness a injector resistor box and a si dizzy i cant find a full si harness at pick and pull so do i need to just cut dizzy plugs and injector resistor plugs off a sedan or si and splice em in?
having a kid </TD></TR></TABLE>
These should be helpful
http://www.geocities.com/c_rexboy/mpfi.html
http://www.angelfire.com/d20/h....html
http://hybrid2.honda-perf.org/tech/mattdx2zc.html
OBD1 92-95 injectors and rail will work but….
you have to chip off the tabs on the in side of the injector where it the plug, plugs in.. so it will plug in. that’s if your using the 88-91 si injector plugs.
Old May 9, 2007 | 09:35 AM
Default Re: mpfi ? (danb18c)
i have injectors and plugs with wiring all i nedd for it to work is a intake throttle body
deamn temper
i had like three intakes and three heads got pissed when motor wouldnt work and sent them to aluminum scraper for cash damnit
Old May 14, 2007 | 03:25 PM
bum,p
Old May 14, 2007 | 04:10 PM
janz3n's Avatar
why are you bumping, you got all your answers.
Krisco65
Nov 19, 2009 05:26 PM
DjBurns
Aug 5, 2008 07:19 PM
Corporation
Jun 14, 2005 12:08 AM
Gsr_Hybrid_theory
May 23, 2005 03:33 PM
