VTEC pressure valve wire???
Old May 1, 2007 | 11:18 PM
Charbon Sty's Avatar
Default VTEC pressure valve wire???
so just got the obd1 ecu plugged in with the boomslang harness,
now just realized vtec isnt working anymore, its because obd2 ecu didnt need to have a VTEC pressure valve sonsor?
its a code 22 which is to with the VTEC pressure valve. Still using the obd2 harness.
so does anyone know if there is a VTEC pressure valve wire on the obd2 harness? all i have to do is tap the wire and ground it, just not sure if its on the harness and need to know what color the wire is if its on there.
oh yea this is for a JDM b18c swap
cheers guys
Old May 2, 2007 | 01:16 AM
spork motorsports's Avatar
* B A N N E D *
Default Re: VTEC pressure valve wire??? (Charbon Sty)
threw code 22 on my z6 becuase the green plug was broken on mine replaced it, reset ecu, and its gone
Old May 4, 2007 | 10:35 PM
oh fixed it, on the boomslang harness i hard wired A4 to D6 and vtec is running fine now
JDMjackyboy
May 31, 2011 07:03 PM
TeamRPM_ZC
Jul 14, 2008 08:36 AM
GreddyCivic7
Feb 10, 2007 03:35 PM
CIVIC96DXcp
May 7, 2005 09:27 AM
InfamousRS
May 14, 2002 07:23 PM
