Check out my titanium retainers
After my timing belt broke, I had the valves pulled (8 intake are bent) and noticed my titanium retainers (not sure what brand, NOT Portflow) were badly worn. Keep in mind these retainers have had 3 different valve spring set-ups in their lifetime (about 35,000 miles).
ITR stock springs, Toda B cams
ITR outer, Portflow inner, Toda B cams
Toda springs, Toda C cams
Can you tell which is stock?
Anyone want to guess how long before they would have broke? How much lift I was missing? What the spring pressure was due to the height and wear?
[Modified by TodaSi, 2:46 PM 6/4/2002]
[Modified by TodaSi, 2:57 PM 6/4/2002]
bottom left = stock.
Bottom right is a good example of the gouging, outter rim should be flat and smooth.
.....what are you going to use now? Nitride treat some portflow ones?
BTW seat pressure was 35 lbs. Stock is 40 lbs, Toda (at the correct height is 50 lbs)
[Modified by TodaSi, 2:58 PM 6/4/2002]
Wow !!
Looking at these pic's has me worried about my Portflow ones that I have now...with only 10000km on them so far.??? Guess it's time for a look!!
The thicker one are the Ti ones ?
One is the stock one (with 10,000 miles on it) which is the correct thickness, the other two are the titanium retainers that are worn very thin.
What Shane said.
Holy ****...that's a pretty bad wear on those retainers...
TodaSi, do you have ITR's lost motion assemblies, or are you still using the B16 valvetrain? I am not sure if there's a realation between the LMA's and the wear, but it's good to put that into consideration as well.
My Crower's TI retainers have been running in my motor for a good 35000 kms now, and if mine were to wear at the same rate as yours, I think I am running on no retainers now... but I am very curious to know the cause of the premature wear.
[Modified by TodaSi, 2:47 PM 6/4/2002]
SGT,
I guess this might be a noobie question but how does the LMAs effect the VTEC engagement and noise ? Also, does really matter if you use a ITR ones versus non-ITR ones ??
wow............i thought the valve spring itself would gaul and wear since titanium is much stronger............i would have never thought ti-retainers wear out........
makes me wish i kept my stock retainers instead.........
just to be on the SAFE side with my motor, I'll be changing my timing belt ever 15k at least
and the retainers and possibly valvesprings and LMA's depending on wear every 30k or so....maybe water pump too and various other tiny things
