Car will not do anyting?!?!?!
Ok I bought this civic been setting since 02, pulled motor cleaned up tucked wires painted car bla bla bla put together and went to see if it would start and it did noting. Like i mean nothing. No radio or anything. Then i pressed the hazards and they light up solid and the relay for blinkers buzzes like the main relay does when it goes out. but not main relay. Any ideas???
no i just hid wires no re soldering or redoing wires. And ECU was plugged in because i did look at that. Also my radio would have worked even without ECU. See i thought it was my main relay but i looked at it and was like thats not my main relay?!?!?!?!
You said the car had been sitting, correct? If it was outside, then theres a high probability that rust/corrosion/humidity has taken its toll on other wiring components and their grounds, maybe not on the actual wiring harness. Make sure the actual ignition on the steering column is still in tact and wired correctly.
You checked to make sure all grounds were ok, none left hanging when you did the wire tuck?
This might sound dumb but hey I gotta ask, did you try a new battery?
Check all fuses? engine bay and underneath dash?
Electronis only need power and ground to really work, so if you radio is not working its one or the other. Just have to find out where the power is stopping or where the ground is not attached.
GL
GL
perm712
Nov 14, 2006 11:56 AM
poundedhatchcrap
19
Jun 22, 2005 05:53 PM
