Auto up/down BOTH windows
Whats needed to make both windows up/down with the auto function located only on the drivers side?
is it just the switch?
are there any other parts to replace? how much would it cost?
comments welcome
comments welcome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misterghost »</TD></TR><TR><TD CLASS="quote">Whats needed to make both windows up/down with the auto function located only on the drivers side?
comments welcome</TD></TR></TABLE>
Basically, you need another relay. Most aftermarket alarms have it as an add-on option. Not sure if there is a way to custom rig it otherwise.
Isn't the driver's switch a 2 stage momentary switch? I wonder if we could just change out the passenger switch....??? I'm a lazy *** like Mr. Ghost up there and just want to click once to close the window.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by COMplex. »</TD></TR><TR><TD CLASS="quote">
Basically, you need another relay. Most aftermarket alarms have it as an add-on option. Not sure if there is a way to custom rig it otherwise.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misterghost »</TD></TR><TR><TD CLASS="quote">how about not requiring an aftermarket alarm?
whats the simplest solution to this?</TD></TR></TABLE>
Someone had done it with the oem keypad but still needed the relays etc
all windows auto up/down would be real slick. the tC is like that, and i had a 328i with all 4 windows auto and i miss it. plus you can hold down the unlock button on your keyless entry and all of the windows and moon roof will open. that would be nice to rig up.
crapanese
Sep 14, 2008 01:33 PM
