Rust under paint suggestions
Old May 1, 2007 | 07:07 PM
ampm's Avatar
Default Rust under paint suggestions
I'm gonna be removing the shitty paint job paint from the rex here pretty soon.. I'm assuming air craft would be choice to do this with? Also, there's chips all over the place on the body, so I helped one along and noticed some rust. Would this only be a case of surface rust? And would sanding be the best way to remove it before new primer/paint etc?
Thanks
Old May 1, 2007 | 08:41 PM
harmonator84's Avatar
Default Re: Rust under paint suggestions (ampm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ampm &raquo;</TD></TR><TR><TD CLASS="quote">I'm gonna be removing the shitty paint job paint from the rex here pretty soon.. I'm assuming air craft would be choice to do this with? Also, there's chips all over the place on the body, so I helped one along and noticed some rust. Would this only be a case of surface rust? And would sanding be the best way to remove it before new primer/paint etc?
Thanks </TD></TR></TABLE>
This should be asked in the new Paint and Body section.
Old May 2, 2007 | 02:55 PM
ampm's Avatar
Default Re: Rust under paint suggestions (harmonator)
Ah. Thank you =]
bubba cola
Paint and Body
25
Mar 4, 2009 04:36 AM
EJ8 Kenobi
Paint and Body
May 15, 2007 09:15 AM
ampm
Paint and Body
May 2, 2007 05:16 PM
JDM RHD eg6
13
Nov 20, 2006 10:08 AM
trooper0641
Oct 11, 2004 12:48 PM
