Z6 into 90 Si
Old May 1, 2007 | 06:06 PM
Aquafina's Avatar
Default Z6 into 90 Si
I searched around and can't find all the answers.
Have a 90 CRX Si shell. Using a Z6 longblock, Z6 engine harness, ECU, and dist. Either using a Boomslang OBD-0 to OBD-I harness or fabbing it up on my own with new Honda connectors. The only mount that the CRX came with was a trans mount that bolts to the passenger side. The Z6 came with all the mounts, except the rear bracket that the 5/6g uses. I know I have to use the 4g drivers side mount. Which other mounts do I use (other than the trans mount that it has right now). Also which axles will work? I have a set of 5g and 6g. Can I use those or do I need to get 4g axles?
Old May 1, 2007 | 06:38 PM
Ilovemyef9's Avatar
Default Re: Z6 into 90 Si (Aquafina)
I had the same motor in my car and i use everything off my EF hatch mounts and axles and they work just perfect, I don't think the Z6 mount will work they didn't work for me or the axles and u going to need a cable tranny.
Old May 2, 2007 | 04:44 AM
Aquafina's Avatar
Default Re: Z6 into 90 Si (Ilovemyef9)
Have an A6 trans I'm putting a 4.71 FD and 1.033 4th into.
Old May 2, 2007 | 04:57 AM
rasta420's Avatar
you will be using all A6 mounts because you are using the A6 tranny. 3 tranny mounts, and one drivers side mount you need to transfer from the A6 to the Z6. you will need to use the axles for the A6 tranny.
Old May 2, 2007 | 05:01 AM
Aquafina's Avatar
Default Re: Z6 into 90 Si (rasta420)
Thanks.
MGX
Jun 23, 2013 06:06 PM
AlfieRoach
61
Sep 16, 2011 11:47 AM
user 98292739
Jun 9, 2006 04:08 AM
AgentJam
Sep 7, 2004 08:36 PM
vha27
12
Jan 22, 2004 03:31 AM
