Crazy Idle Issues
Hello I keep having irratic idling on my 94 swapped ITR. the check engine light is on so I checked the to see what code it was throwing and it was 41 the o2 sensor. Would a bad o2 sensor make my idle go from 1k to 2.5k up and down... if not what eles could it be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scotty2H »</TD></TR><TR><TD CLASS="quote">http://www.ef-honda.com/ben/Badidle.php</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyitrboy »</TD></TR><TR><TD CLASS="quote">check your coolant. could also be a bad iac valve. take it out and clean out the
screen.</TD></TR></TABLE>
Sounds good I'll try them tomorrow.. I'm gonna check the FITV to from what i can read, this is what is happening to me I guess, it does it right as you start the car but continues all the time. So I'll athry the IACV too..
Thanks
Thanks
check the throttle body after the car is kool, take a 8mm wrench and take the flap off the back of the throttle body and screw the plastic part clockwise til it stops. Put the 8mm bolts back in and start the car, should be fixed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooch’n »</TD></TR><TR><TD CLASS="quote">check the throttle body after the car is kool, take a 8mm wrench and take the flap off the back of the throttle body</TD></TR></TABLE>
I don't know what one to take off...I just looked at it and can't tell where the bolt is or which one it is... A picture could help me if possible. otherwire I'll just look better... and do I have to remove my intake to reach it?
Is the Flap you are talking about the black thing on the TB?
poormans_typer69
Oct 30, 2007 05:10 PM
